| 1st gear a bit stiff? hi i've my grande a week now, but i've noticed when putting it in first gear it's bit stiff when i'm coming up to a roundabout or somethin, but when the cars still, it slips in fine, has anyone noticed this with theres?? it feels like its rubbing against something a bit. maybe its coz its new i dunno...im already being booked in to the garage to sort my bluetooth out i dont need aymore problems! ta
| | #2 | ||||||
| Re: 1st gear a bit stiff?
__________________ http://www.xs4all.nl/~bvdam/temp/teddysig.png
| | #3 | |||||
| | #4 | |||||
Most cars are like this as first gear is so much shorter than the other gears, it helps prevent an over-rev if you accidentialy were going down the box to 3rd and got 1st instead. Saves the engine a lot of hassle!!
| | #5 | ||
| Re: 1st gear a bit stiff? All manual cars i believe will not go into first gear easily until the car is close to standstill - below 5mph... If your approaching a roundabout, try 2nd gear
| | #6 | ||
| Re: 1st gear a bit stiff? cheers guys glad thats been cleared up, makes sense i spose. i noticed that puttin it in second when ur pretty slow doesn't seem like its makin the engine struggle too much so i'll just do that from now on
| | #7 | |||||
In my previous 2 Puntos - a Mk1 and a Mk2 - I could just chug slow and steady in 2nd with no feet near any pedals on level ground. Try it ![]()
| | #8 | |||||
| | #9 | ||
| blessed are the apostates | Re: 1st gear a bit stiff? the ecu tries to maintain the idle rpm so engine braking doesn't occur at very low revs, unlike a carb engine that would stop
__________________ ![]() | ||
| | #10 | |||||
| | #11 | ||
| Re: 1st gear a bit stiff? Aha! Thought something like this was going on... being a freshly passed driver my instructor taught me if I was approaching a roundabout in second or third not to shift down but to brake and clutch if I had to stop and only use first if i had stopped and was pulling away, as it was my habit to freewheel it into a roundabout, which they dont like - something to do with engine braking and staying in control. Makes sense now! Thought the gearbox might have been gooosed! looks like I just have to get used to the car a bit more...
__________________ "Some days you get the bear, some days the bear gets you..." Wiliam T Riker | |||
| HELP - Lost 1st gear?!? | blu73 | Cinq/Sei > Technical | 4 | 02-08-2006 08:17 |
| noise in neutral, 1st & 2nd gear | commiepanda | Panda (Classic) | 5 | 26-04-2006 23:07 |
| Something wrong with my Punto triptonic gear!! | Shidi | Punto > Technical | 1 | 02-11-2004 07:32 |
| Cinq Thumping Out Of 2nd Gear | GhostWKD | Cinq/Sei > Technical | 17 | 22-09-2004 06:06 |
| Ooof - me gear box. 1.6 16v Bravo | m_a_r_k_o | Bravo/a > Technical | 2 | 29-08-2003 15:28 |
