| do sporting m-jets have any form of esp? ok maybe a stupid question but would an 06 plate sporting m-jet have any form of esp? the traction control works the hill holder fuction works just wondered if these were tied into an esp type system at all? and if so how do i check its operating correctly before my warranty expires! cheers
| | #2 | |||
| Chasing Cars | Re: do sporting m-jets have any form of esp?
Just be bloody careful make sure theres no other cars about etc . | |||
| | #3 | ||
| Re: do sporting m-jets have any form of esp? i thought that ESP was standard on all GP sportings!! mine has, so if your m-jet doesn't then theres something wrong!! ![]()
__________________ | |||
| | #4 | ||
| Re: do sporting m-jets have any form of esp? oh, and mine definately works, as i found out hitting a corner a bit too quick, a week after it being delivered!! ![]()
| | #5 | ||
| Re: do sporting m-jets have any form of esp? If there were any faults in the ESP system you'd have the ESP, and probably ABS, warning lights on constantly.
| | #7 | ||
| Chasing Cars | Re: do sporting m-jets have any form of esp? IT was an option on the early 1.4 16v sportings. Always been standard on mjets and tjets. | ||
| | #8 | ||
| Re: do sporting m-jets have any form of esp? well mines an 08 chris, and it was definately standard, coz im scottish and a tight git!!! lol!! ![]()
| | #9 | ||
| Re: do sporting m-jets have any form of esp? if you have a remap you'll see the light ALOT of the time.
| | #10 | ||
| Ray Von | Re: do sporting m-jets have any form of esp?
| | #11 | ||
| Re: do sporting m-jets have any form of esp? er....this is gonna sound really daft, but whats the difference between ESP, traction control, and slip diff? coz i thought the three of them did the same sort of thing! ![]() im a bit daft when it comes to mechanics, so don't laugh too hard!! ![]()
| | #12 | |||
ESP - Stability control usually applying brakes to certain sides of the car to steady the vehicle when going round corners (i'm almost sure this is how esp works?) Limited slip diff (LSD) - helps with grip in cornering by giving different rotational freedom to each wheel.
| The following user says "Thank You!" to puntokris for this useful post: | ||
steve119 (13-07-2008) | ||
| | #13 | ||
| Re: do sporting m-jets have any form of esp? cheers, so instead of having limited slip diff, we have ESP that kind of does the same thing, but does it in a different way with brakes, instead of kicking in with different wheel speeds to get grip back? and do we not have a sort of traction control eith ASR? coz i thought there was something called EBD to stop the car from spinning?? ![]()
__________________ Last edited by steve119 : 13-07-2008 at 21:13. | |||
| | #14 | ||
| Re: do sporting m-jets have any form of esp? forget about the first bit coz i've realised it was a load of rubbish, the limited slip dif is a wheel orientated thing to stop losing grip in the first place, but the other two is to gain grip when you don't have it anyway? lol!! ![]()
| | #15 | ||
| Re: do sporting m-jets have any form of esp? ok now i am confused i always thought ebd was electronic brake force distribution basically an improved version of abs? traction control is fairly obvious yeah the light flashes way when putting the boot in on greasy roads. and no as far as i am aware no gps have an lsd? as i said am sure my abs and traction control works as does the hill holder function and i get the asr light illuminate on start up thengo out and only flicker on to stop wheel spin so i assume its all working ok
| New Comer form france | wst62 | Newbie Central | 2 | 09-06-2008 00:56 |
| Are Sporting washer jets heated? | Zonda_ | Punto | 2 | 15-10-2007 23:53 |
| 1.4 16v Sporting - ESP & MSR & ASR | mattahchoo | Grande Punto | 2 | 18-09-2006 15:20 |
| HC1 form? | The Negotiator | Leisure Lounge | 21 | 25-09-2005 00:47 |
| anyone form near derby? | Dunc Maclean | Leisure Lounge | 1 | 20-03-2004 16:47 |
