The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto > Grande Punto > Technical
Old 05-07-2008   #1
Trader Rating: (0)
Unhappy Any one else had a petrol smell from air con?
Hi
In the last month our Grande Punto 1.4 Dynamic has started to produce petrol smells in the cabin when the air con is on. Has any one else come accross this problem? Would any one know what is causing this?
We originally thought it might be a vehicle that we were driving behind but it has happened on too many occaissions to be this. I have never come accross this before in any cars with air con that I have had (Ford KA, MINI, Fiat Panda and Fiat 500).
Thanks.
fiatdriverleeds is offline
Old 06-07-2008   #2
Trader Rating: (0)
Re: Any one else had a petrol smell from air con?
Originally Posted by fiatdriverleeds View Post
Hi
Thanks.
Sounds like you might have a small petrol leak under the bonnet. I would examine all the fuel pipes inside the engine bay. It is up to you whether or not you do this with the engine running but any fuel is likely to evaporate fast when the engine is hot. You should therefore smell it if you open the bonnet.
Mad Mike is offline
Old 07-07-2008   #3
He Who Dares Wins
marty61's Avatar
Trader Rating: (0)
marty61 has donated! United Kingdom
I don't have air con but i get an occasional smell of petrol from the vents. checked under bonnet and car but no sign of any leaks. Could be fuel tank vent or engine overfueling
06 GP 1.2 Active-3 Door-Bolero Red.
If it aint broke, take it to bits anyway.
marty61 is offline
Old 08-07-2008   #4
Trader Rating: (0)
If it's a 1.2 or 1.4 8v, check the cam cover to air filter breather hose (under the filter housing).
I've known a couple to split/perish allowing the crankcase blow-by gases to seep out and get drawn into the car through the vents rather than being directed back into the inlet manifold.
D4nny8oy is offline
vB code is On
Wanted: Air Con Pump 1.6 Petrol model. (FIAT Multipla Parts Wanted) topwally For Sale / Wanted 0 30-05-2008 09:29
air con / pollen filter / low air stream ??? its_jon Stilo 15 13-05-2008 19:45
Stilo Active Air Con - No Air Con andrewduerden Stilo > Technical 8 11-05-2008 18:15
Smell for air con/heating poggy Ulysse 3 19-06-2006 09:12
Evaporator/Air Con smell hatters1999 Bravo/a > Technical 4 24-07-2004 15:44
