| Good afternoon! Does anyone know how long the air should last without needing a re gass? Reason is mine has decided to pack up, and after a phone call to the Fiat garage they have told me it probably needs a re gas at a cost of £130. Is there any way I can check if a re gas is needed, as I can get it done much cheper if that is all that needs doing. The Fiat dealear has told me there is no way to check unless I pay for a re gas before they check if it has any faults which they will then fix under warranty. Help from anyone who knows about this kind of stuff. Cheers!
| Shady By Name And Nature | Re: Air con not working Wifes Corsa is nearly five years old, never had a re-gas, air con still ice cold. Dont think i would be paying for a re-gas before they have even looked at it.
| | #3 | |||
| A Panda with Gadget's | Re: Air con not working
£130.Kwick fit do it for about £40 I think ![]() The only way to tell is to get it linked upto one of the re-gaser's I think, which will do a gas level check, and pressure check, and will do an auto check of the system for leaks if there is low pressure or no gas ![]() How often do you use air-con as it's recomended to run it for atleast 5-10 min a week to keep the system working and to stop rubber seals from cracking and causeing system leaks with often cost more than it's worth to fix ![]() Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | |||
| | #4 | ||
| Re: Air con not working I used it fairly often certainly once a week at least! the garage say its not uncommon to need gassing after 2 years! mines only 18 months old.
| | #5 | |||
| | #7 | ||
| | #8 | ||
| Re: Air con not working My GPS had to be re-gassed as the aircon was blowing warm. Thankfully mine was covered under warranty. I had a 52 plate stilo and the aircon was blowing warm, had it checked by some guy who was mobile, he couldn't find any leaks so he re-gassed it. Two weeks later, warm again, got him out again, and this time he found a leaky pipe, it was the long one that runs from the pump, the one Fiat never stock, he fit the pipe, re-gassed and happy days, ice cold again.
__________________ 1.9 GP Sporting Chemical Grey My GPS:Punto & Side badges removed http://www.fiatforum.com/members-mot...-gps-mjet.html | |||
| | #9 | |||||
| Air Con not working | PlanetPD | Multipla | 2 | 27-05-2008 23:16 |
| Air Con not working - Stilo | Crazy Jo | Stilo > Technical | 7 | 09-08-2007 09:39 |
| air con not working | jon8152 | Punto | 3 | 14-07-2007 23:28 |
| air con only half working!!!! | tetley85 | Stilo > Technical | 20 | 06-07-2007 18:07 |
| Air con not working | Besty77 | Bravo/a > Technical | 14 | 22-06-2006 08:30 |
