| He Who Dares Wins | I have been searching for the dreaded creaking for nearly 2 months now, and its the DOOR LOCKS. How do i know well If you close and lock the doors then push down on the top edge of the door with one hand and gently lift by the door handle with the other hand you replicate the door movement as when the body flexes over bumps etc. You can hear the creaking noise coming from the striker/lock area. Spray the door seals first to eliminate them though. Now ive found it just got to sort it RING RING HELLO MR DEALER TYPE PERSON.
__________________ 06 GP 1.2 Active-3 Door-Bolero Red. If it aint broke, take it to bits anyway. | ||
| Mo Money, Mo bass | Re: Creaking--FOUND IT I've got this! Its a white
| | #4 | ||
| Re: Creaking--FOUND IT You have to remove the door striker plates. On removing the striker plate you will see that the two captive nuts behind the plate are able to move to allow greater adjustment to the it. These are whwt make the noise !!! Get your hands on some copper grease and some spray lube, with a small paint brush. Copper grease around the captive nuts (Just shove it in really), then spray in some grease. Re-attatch the striker plate to them approx same position it came off. Check that the door open and closes freely making sure that the door does not stand out leaving a large gap. Go for a road test. It may do it a few more times but will soon stop once the grease has worked in. ![]() Or!!! Take it to your main dealer and just use your warranty ![]()
| The following 2 users say "Thank You!" to simmybobjnr for this useful post: | ||
dannyb-with-a-gp (24-06-2008), marty61 (12-06-2008) | ||
| | #5 | |||||
| | #6 | |||
| He Who Dares Wins | Re: Creaking--FOUND IT
__________________ 06 GP 1.2 Active-3 Door-Bolero Red. If it aint broke, take it to bits anyway. | |||
| | #7 | ||
| He Who Dares Wins | Re: Creaking--FOUND IT UPDATE Just been messing about with it and found the striker was rubbing on the latch so i repositioned the strikers into the centre of the latch slot and gave it a spray of WD40. Been for a test drive and went to the roughest road i could fine and its quiet as a mouse. It must have been the striker and lock moving against each other. ![]()
| | #8 | ||
| Shropshire UK | Re: Creaking--FOUND IT Drivers side window can cause this too, wind it down then a quick "up" on the winder button, takes up the play between the glass and the mechanism. Try it. Alternatively you could just push the window down when u dropped it a few inches. Mine moves about 5mm when I do this but there is NO rattle.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #9 | ||
| Forum Moderator | Re: Creaking--FOUND IT
| | #10 | |||
__________________ 06 GP 1.2 Active-3 Door-Bolero Red. If it aint broke, take it to bits anyway. Last edited by marty61 : 13-06-2008 at 20:23. | |||
| | #11 | ||
| Forum Moderator | Re: Creaking--FOUND IT agree...had customers reporting noise from rear when it was infact the door locks. 2 quick tests; 1) wrap bit tape around striker plate & see if noise goes away. 2) drive on bumpy ground & open door, if noise stops its the door lock (safety here guys, private ground & wear seat belt)
| | #12 | |||||
With reference to my post "Warranty issue - Bodywork" Having just read your post, I carried out test number 2 and guess what? No creaks from the nearside! My dealer thought it was a bodyshop issue, now thanks to you, I can point them towards the right direction! No more time off work for me then! High praise indeed ![]()
| | #13 | ||
| Forum Moderator | Re: Creaking--FOUND IT sticking a bit of sellotape (so you cant see it) around striker plate is all thats needed.
| | #14 | ||
| Re: Creaking--FOUND IT fiat... sellotape.... quality? :P
__________________ | |||
| | #15 | ||
| Creaking? | The Street End | Grande Punto > Technical | 45 | 11-03-2008 08:58 |
| creaking/rattling | d_reaper21 | Punto > Technical | 0 | 01-11-2007 23:18 |
| creaking | vodkacab | Punto > Technical | 10 | 12-06-2007 14:54 |
| Help creaking and ecu | Emma83 | Punto | 3 | 15-09-2006 16:39 |
| Creaking window | Big Black Stilo | Stilo > Technical | 26 | 02-08-2005 21:58 |
