The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto > Grande Punto > Technical
Old 12-06-2008   #1
Trader Rating: (0)
Malaysia
crunching noise when engaging reverse
my duologic was changeed recently while under warranty. even that it still does not eliminate the problem of crunching noise when engaging reverse gear.
somewhere in this forum, it was mentioned that some rod need to be replace to longer ones. does anyone knows which rod exactly. than i have problem to convince my only service centre to change the rod.
i have some suspicion that the pressure not enough causing the rod pusing the clutch too slow while the auto engage the reverse lever.
any suggestion?
note: the service centre managed to reporgram back the duologic, now its as reponsive as before.
ahhl is offline
Old 12-06-2008   #2
SNAP!
luvduvs's Avatar
Trader Rating: (0)
luvduvs has donated! Australia
Re: crunching noise when engaging reverse
Happens to me every now and then (http://www.fiatforum.com/grande-punt...rse-grind.html) - have been told its normal.
As its intermittent I would imagine you'll have a tough time getting your dealer to diagnose the problem, let alone fix it.
Good luck anyway
I have anger management issues
luvduvs is offline
vB code is On
crunching noise when engaging reverse ahhl Grande Punto > Technical 0 12-06-2008 01:31
Crunching reverse gear............ MONKEY_RIDER Multipla 0 26-08-2007 00:14
Gearbox Problem - shaking when engaging 1st or reverse FiatStiloJTD Bravo/a > Technical 7 06-06-2007 15:34
Crunching when selecting reverse/Brakes Superboy Grande Punto > Technical 29 06-12-2006 23:53
Gear crunching going in reverse Randomman Cinq/Sei > Technical 1 04-10-2005 22:23
