| Flat Spot Over the past few months, an annoying flat spot has developed on my GP 1.9 Sporting. It tends to happen mainly when the engine is cold, whilst accelerating in 2nd or 3rd gear, and feels like a momentary loss of power (like I've suddenly let go of the accelerator and put it back again). It's at low speeds (up to 30mph) and below 3,000rpm. Dealer has looked at it twice and updated ECU, but has been unable to re-create. Any suggestions please?
| Re: Flat Spot Same prob as me mate. ECU update does nothing for it either. Fault with mine is a sudden loss of power and double jerk (pardon the pun) around 2 n half thousand revs in second gear while cold, in every 1 in maybe 10 cold starts
| | #3 | ||
| Re: Flat Spot I had the same thing, after i changed the MAF,not as violent though just a slight hesitation at 2600RPM in third. I had a MAF problem changed the MAF and it went away for a couple of days,i then put and enclosed IDNK in as i had to break up the original air box to change the filtter,so could get an IDNK easeir than the OG air box. Any way it came back but worse,the new MAF i got was a cheapie of fleebay and was advised get rid and get a bosch so did,and it went away,but still sometimes gives a little hesitation when warm not when cold.??? It is a puzzler. Scotty | |||
| | #4 | ||
| Re: Flat Spot Glad I'm not the only one with this! Yep, the problems you're both describing is exactly the same as me. Guess my only option is to take it back in to the dealer and try to demonstrate....I'll just have to leave it there all day and demo it after work when the engine is cold. Trouble is, it doesn't do it on every trip, so it'll be s*ds law that it won't do it!
| | #5 | ||
| Re: Flat Spot Has anyone who had a flat spot in the GP managed to fix it/find the problem? Mine's still there, but better if I only fill with Shell - any other diesel and it's much worse. Cheers
| | #6 | ||
| Shropshire UK | Re: Flat Spot I only use Shell and so far have not seen or felt this in 30k miles.
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | ||
| | #7 | ||
| Re: Flat Spot Weird...obviously something unusual!
| | #8 | ||
| Red all over the land | Re: Flat Spot I to have a 1.9 mjet sporting and the very same happens with mine, it went in for it's first service last week and even though i mentioned it to them they found nothing wrong, glad (if that;s the right word) to hear i'm not the only one, please advise if anyone gets a fix to this.
| | #9 | ||
| Re: Flat Spot Yeah mine has the same problem. Been to the dealer 3 times, updates done, but the problem persists . Mine is a June '06 build 1.9 Sporting. Would be interested to see if this defect is present in later model vehicles or if the fault has been identified and fixed by Fiat. What are the build dates of your vehicles???
| | #10 | ||
| Re: Flat Spot Yep, mine is a June '06 build too...coincidence??!
| | #11 | ||
| Shropshire UK | Re: Flat Spot Mines a 56 plate, not sure of the build date.... where is that guys? Maybe its a pre 56 thing... in which case FIAT should know what the cause is..
| | #12 | ||
| Re: Flat Spot mmm mines a an 06 plate as well anyone tried an aftermarket remap see if this cures it?
| | #13 | ||
| | #15 | ||
| Forum Moderator | Re: Flat Spot I'd be closely looking at the operation of the EGR valve.
| | ronnieronson | Cinquecento / Seicento | 23 | 02-06-2007 09:20 |
| | chazzer | Cinquecento / Seicento | 53 | 25-04-2007 22:02 |
| | EvilJaxx | Cinquecento / Seicento | 17 | 06-05-2005 12:44 |
| | Bushboy | Cinquecento / Seicento | 16 | 16-03-2005 22:59 |
| | Brymak | Uno | 3 | 29-11-2004 03:06 |
