The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 11-07-2007   #1
Trader Rating: (0)
AUX Input
OK I have a Grande Punto and on the radio menu you can select AUX but I cannot find any input and it is not mentione d in the manual.
I was wodering if there was an input or how to make an input.
kclives is offline
Old 11-07-2007   #2
Straight outta H-ton!
dannyboy83's Avatar
Trader Rating: (0)
dannyboy83 has donated! United Kingdom
Re: AUX Input
it's not on the back of the head unit by any chance is it? I'm sure my old standard ford stereo had one on the back, which I only noticed when I took it out to put an aftermarket one in.
dannyboy83 is offline
Old 11-07-2007   #3
Trader Rating: (0)
Re: AUX Input
I really have no idea?!?
I think i will have to take out unless anbody can help...
kclives is offline
Old 11-07-2007   #4
Trader Rating: (0)
Re: AUX Input
It is for ipod connector - however you have to but the interface kit to make it work. This kit plugs into back of radio on non blue and me cars.
See earlier thread
http://www.fiatforum.com/grande-punt...rior-trim.html
Shauncorwyn is offline
Old 11-07-2007   #5
Trader Rating: (0)
Re: AUX Input
If you've got Bluetooth/ Blue&Me it's the USB port in the glovebox (left hand side) for connecting up your MP3 player to listen to your music through the radio.
You should have a separate manual for the radio.
D4nny8oy is offline
Old 11-07-2007   #6
Trader Rating: (0)
Re: AUX Input
I'm thinking of the Ipod connector for my standard headunit which came with my 1.4 Active Sport. Do I have to take the headunit out to plug in the Ipod connector or can I get access to the back of the headunit from behind the fascia?
steem21 is offline
Old 12-07-2007   #7
Trader Rating: (0)
Re: AUX Input
Originally Posted by steem21 View Post
Yes the head unit has to come out - this is easily done by making 2 u shape tools from an old metal coat hanger or you can buy them from h**Fords.
You only have to do this once and you can locate the ipod where ever you want as the cable is quite long.
Old 12-07-2007   #8
Trader Rating: (0)
Re: AUX Input
Where do you insert the "coathangers" to remove the headunit - I've noticed a few holes on the front of the headunit - are the screws in there?
steem21 is offline
Old 12-07-2007   #9
Trader Rating: (0)
Re: AUX Input
There are four small holes on the front of the radio - there are no screws
Old 14-07-2007   #10
Aresby's Avatar
Trader Rating: (0)
Aresby has donated! United Kingdom
Re: AUX Input
On some radios there are anti-theft grub screws in the holes to prevent thieves removing the radio in about 30 seconds.
The screws have to be removed first using a small allen key. Not all radios have them though (up to the factory/dealer to fit them after the radio was installed so easy to forget/not bother).
If you have them fitted don't forget to refit them to prevent the aforesaid thief making off with your radio!
"There's no point going through life being a pessimist. It's probably not possible anyway"
Aresby is offline
AUX input forevertom Panda (New) 3 06-03-2007 08:20
very strange problems using Aux input bulldog5046 I.C.E 8 01-03-2006 17:35
Sat Nav Aux input help!!! fieldy I.C.E 0 05-02-2005 22:37
(T) AUX input on Connect Nav+ pc99 Stilo 2 27-10-2004 08:34
aux input on sony head unit? arc I.C.E 11 13-07-2004 02:50
