| ASR Fault !!!! Since ive had the punto the ASR light comes on and disables it and the hill holder funtion, in the last 3 months its been back to the dealer 3 times and low and behold its stopped again...fisrt few times they said it was randomw and wiped the fault off, last time it went in they said it was something to do with the steering...this morning just about to pull out from petrol station and the steering locked couldnt move it one bit ...turned the engine on and off and it was fine. Anyone else had this problem, its really pi55in me off. i want everythin sorted before i have a remap but it will be ages off if this keeps happening !!!!!
| Forum Moderator | Re: ASR Fault !!!! Moved to technical section Dave have you had all available software updates yet?
| | #3 | ||
| Re: ASR Fault !!!! Please tell me more ...its been in the garage a few times so would assume if any needed doing then they would have done it !
| | #4 | ||
| Forum Moderator | Re: ASR Fault !!!! Theres at least 3 software updates available for the GP most important one for the body computer...simply suggest to garage can they check they have been done. (if they dont know how tell them to go into 'control unit programming' on examiner & check each section)
| | #5 | ||
| SNAP! | Re: ASR Fault !!!! How often are updates made available - is it only when a fault/glitch has been discovered or are they available regularly regardless?
| | #6 | ||
| Re: ASR Fault !!!! the last time it went in they said they had recallibrated the power steering and deleted the fault...thanks for the advice..i will ask the next time it goes in
| | #7 | ||
| Re: ASR Fault !!!! I took the car back to Fiat today and they advised it will need a new steering column. apparently the asr / hill holder electrics all sit within the steering column..im also awaiting Fiat to get back to me about my alloys..will see if they will agree to replace /refurb them due to the centre caps issues that a few people seem to have had on this forum
| | #8 | |||
| Re: ASR Fault !!!!
sorry you've not had much luck with it Dave....
__________________ Current car: red GP sporting, 1.9 (158bhp, (147bhp at the wheels) and 314 lbs/ft ) last car: fabia vRS, 160bhp, 80k by the time I'd finished with it. Gone, but not forgotten. | ||||
| | #9 | |||||
| | #10 | ||
| Re: ASR Fault !!!! Im kinda used to it, every car i have had i always seem to have a few niggles including my old fabia vrs ! On a positive though the people at Fait seemed very pleasent and had a chat with the service manager. They havent done may GP sporting services and i was trying to figure out if mine was due ! Its done 13K they said i could have a full service for 190 quid or one for 130 quid that did not include changing the oil or DPF....! I will be going for the full service once all the parts are available.
| | #11 | ||
| Forum Moderator | Re: ASR Fault !!!! Changing the DPF
| | #12 | ||
| Re: ASR Fault !!!! the guy said it had a dpf ( deisel particulate filter) ..im not familiar with the common rail fiat engines...i know a little on the VAG engines with DPFs.. he defo said it needed checking with a full service.
| | #13 | ||
| Forum Moderator | Re: ASR Fault !!!! wont be changing it as its expensive...it will be too see if its clogged & regenerate (clean) if required.
| | #14 | ||
| Re: ASR Fault !!!! sorry i didnt mean replacing it just giving it a clean etc..
| | #15 | ||
| Re: ASR Fault !!!! The car has had new steering column but the fault is still there, so its being investigated again by the dealer at weekend ...i hate electrical problems....being waiting for a remap for ages but cant get it till this is sorted...very annoying, plus still waiting for a fiat bod to look at my wheels !
| | dogmatix | Stilo | 8 | 01-10-2008 23:35 |
| | grezzza123 | Stilo | 20 | 23-01-2008 10:07 |
| | smify999 | Stilo | 12 | 13-10-2006 18:29 |
