The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 13-06-2007   #1
Jason_6780's Avatar
Trader Rating: (0)
Question 1.4 16V 56 Plate - Out of OIL
I had a quick look through the manual, can't seem to find what oil it needs.
Any ideas? Also wonder why it would be near enough empty after only 7-8 months.
Jason_6780 is offline
Old 13-06-2007   #2
auto_blanco's Avatar
Trader Rating: (0)
Re: 1.4 16V 56 Plate - Out of OIL
5w-40 Selenia from the dealer, I personally always prefer to use the pukka stuff. Cars use more oil when they are new and all engines have a limit as to how much they should "use" in service, plus, the starjet engine only holds just under 3 litres of oil, so there is not much to get rid of!! you should always check weekly really because new engines as they loosen up will use some.
auto_blanco is offline
Old 13-06-2007   #3
Trader Rating: (0)
The 1.4 16 valve 'starjet' engine is known to get through the oil - quite normal and as has been said only takes a total of 2.9 litres.
Be careful when filling it back up......there is only about half a litre difference between minimum and maximum on the 16 valve engine....so it's very easy to overfill it!
Desira, southgate and Thames Fiat both recommend Selenia Performa in the 16 valve engine.
Superboy is offline
Old 13-06-2007   #4
SNAP!
luvduvs's Avatar
Trader Rating: (0)
luvduvs has donated!
You mean the dipstick or where you unscrew the cap with the oil symbol on it?
Also there's an oil warning light that can be used as a backup?
And how many miles have you done?
luvduvs is offline
Old 13-06-2007   #5
Trader Rating: (0)
In most cases I wouldnt rely on the oil light, our Megane checks its own oil level every time you start so when we were on holiday when it was new with around 1k miles on it and it said, top up oil we did and it was fine, but the oil light is to do with oil pressure and once you see it its too late!! However I dont think the Fiat has this self check feature so best make sure yourself.
To make certain, just check it weekly and keep some Selenia with you on a long trip or at home just in case.
Old 13-06-2007   #6
Jason_6780's Avatar
Trader Rating: (0)
Thanks for the info.
I checked the dipstick, i've done just over 8,000 miles. I should have checked it sooner I know..
Oil warning light didn't come on, dad reckons it was just on low as such.
You lot had to fill yours up?
Anywhere you can buy it online? I've tried eBay.
Old 13-06-2007   #7
Trader Rating: (0)
I have a 1.2 gp
The other day i checked oil and it showed no oil on dip stick but after putting in just 1 litre of oil it then showed full on dip stick.
I guess there is only 1 litre tollerance on dip stick from full to empty.
pcman is offline
Old 13-06-2007   #8
Trader Rating: (0)
Ive personally not had to top mine up yet but its only done 2.8k however I do check it every time I fill up. Thats not too often though lol.
The 8v Engine takes just 2.6 litres of oil so as has been said be very careful indeed not to overfill these engines.
Oil consumption will settle down at your sort of mileage but they will consume a tiny bit from time to time. Do you know how much the oil is from the dealers? Any Alfa or Fiat garage will have it.
Old 13-06-2007   #9
Trader Rating: (0)
"Oil consumption will settle down at your sort of mileage but they will consume a tiny bit from time to time."
......No, funnily enough I don't think so.....from what I've experienced and heard I think these engines are all gonna need topping up more than usual.
Of course there's so little oil capacity between max and min levels that it looks much worse than it is and of course their overall capacities are very small indeed. The diesel's are different and I think their capacity is a more regular 3.4 - 3.8 litres.
I changed my oil at 5,000 miles and when I put the first 2 litre can of 'Performa' into the engine there was no reading on the dipstick whatsoever!
......it was only the final half to one litre where it showed.
Hope this helps everyone.
Superboy is offline
Old 13-06-2007   #10
grandemike's Avatar
Trader Rating: (0)
i've done 8k miles in mine, and i topped up at about 6.5k. if i didn't im sure it would have run out too.
btw i used castrol edge 5w-30, and it seems fine on that.
grandemike is offline
Old 13-06-2007   #11
Jason_6780's Avatar
Trader Rating: (0)
Is yours a 1.4 16V 56 model?
You sould be using 5W - 40 not 30..
I think I might just get castrol GTX or something from Halfords.
Old 13-06-2007   #12
SNAP!
luvduvs's Avatar
Trader Rating: (0)
That's why I said backup
I must admit I got paranoid after reading this thread as I haven't checked mine for ages, so I bolted downstairs in my PJs (its 6:30am here) with some tissues - he's a little black but still has plenty of oil after almost 5k
luvduvs is offline
Old 13-06-2007   #13
Trader Rating: (0)
No......1.4 16 valve 'StarJet' Engine takes Selenia Performa Synthetic 5-30w
Castrol Magnatec is semi-synthetic oil -
Mobil 1 would be a better alternative really....
Superboy is offline
Old 13-06-2007   #14
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
I bolted downstairs in my PJs with some tissues
T14086 is offline
Old 16-06-2007   #15
Jason_6780's Avatar
Trader Rating: (0)
I couldn't see a Petrol 5W-40, only diesel 5W-40 in Halfords??
(G) How many GP's are there on the forum? spacecowboy Grande Punto 303 07-09-2008 20:54
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto 543 06-06-2008 17:15
