The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 20-05-2007   #1
Trader Rating: (0)
Ireland
wats a remap???
any body no what a remap is??
leeol is offline
Old 20-05-2007   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: wats a remap???
when the car maker sells the car, the programe on ecu is set to a basic programe that suits most users,
a remap changes that programe to one that gives you a bit more power,
or if you have other engine modifications you can have a live remap that programes the ecu to make the most of the new bits
Binki
dave is offline
Old 20-05-2007   #3
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: wats a remap???
Then I come along & wipe it with a update
T14086 is offline
Old 20-05-2007   #4
Got DISH?
Jamie's Avatar
Trader Rating: (0)
Jamie has donated! United Kingdom
Re: wats a remap???
yeah T, but normally most remap companys take a copy, and do a free remap of your car if your in an evil mood and wipe it
Jamie is offline
Old 20-05-2007   #5
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: wats a remap???
I wouldnt do it intentionally.....i'm not that evil!
T14086 is offline
Old 20-05-2007   #6
Trader Rating: (0)
Re: wats a remap???
For what reasons would a dealer do a software reload
blebo is offline
Old 20-05-2007   #7
smifton's Avatar
Trader Rating: (0)
Re: wats a remap???
Mind if I add to it? basically a engine kind of visualises a 3D "map" of the engine systems, but for this purpoise its the engine valve timing, the fuel injectors and the air intake from the air flow meter. using the position of the throttle it senses how much load is on the engine and chooses the correct information from the map to direct how much fuel etc the engine will need. the manufacter's set it to the happy medium between the economical and performance settings, by remapping it can be altered, so more performance can be squeezed out, sometimes at the expense of economy but normally both can be sorted, particularly on a desiel....see the 170bhp tuning on the 1.9 sporting
Fiat GP 1.4 Active sport in crossover black
smifton is offline
Old 20-05-2007   #8
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: wats a remap???
poor running/idle,sensor reading/voltages etc
T14086 is offline
Old 21-05-2007   #9
Trader Rating: (0)
Re: wats a remap???
my 16v has been in the 6 times with engine faults.
1st time it was running rough at idle, and the rest were loss of power and flat spots. the dealer just reset the ecu and reloaded the software.
by the way is the UPDATE option in the blue and me menu. is the software for the handsfree. i.e a new fone??
grum001 is offline
Old 29-08-2007   #10
Trader Rating: (0)
remap question
Finally got a bit bored of the GP's diesel ommph and want to (need to) get it remaped.
Has anyone thats had their car remapped had it in at Fiat for a service. Just wondering if you've had any problems with them noticing it or sticking on an ECU update and wiping out the remap.
My cars due for a service based on my current milage in about 4 months. Should I wait till after then or get it done now....
Dann is offline
Old 29-08-2007   #11
BEng Automotive Engineer
AlanHod's Avatar
Trader Rating: (0)
AlanHod has donated! United Kingdom
Re: remap question
I have also wondered about this. The manual states a check is done on the ECU whenever serviced. Putting me off getting mine done.
Grande Punto Sporting MJ130, 56 reg, Chemical Grey Metallic, black side stripes.
AlanHod is offline
Old 29-08-2007   #12
Trader Rating: (0)
Re: remap question
thats why i went for the plug in box.
mines from dragon performance and has the power map on it @170bhp.
works a treat and i just unplug it when it goes in the garage.
craig3636 is offline
Old 30-08-2007   #13
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: remap question
A 'scancheck' may be done for errors,this wont involve the remap in any way.
IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER!
T14086 is offline
Old 30-08-2007   #14
Trader Rating: (0)
Re: wats a remap???
Does anyone actually understand what the tuning boxes do. To me they just sound like they trick the ECU into detecting a lower voltage at the fuel rail(hence lower fuel pressure). And therefore the ECU justs responds by increasing the pressure to what it thinks is right.
Is that all it is, because if it is surely it's nothing more than a variable pot, be it a digital one or analogue one. Or am I missing something with regard to the tuning boxes?
Dann is offline
Old 31-08-2007   #15
Trader Rating: (0)
Re: wats a remap???
it only plugs into the fuel pressure sensor on the end of the common rail and takes the 12v supply direct from the battery, it is the digimap plus but i dont know how it works exactly, but it does.
(T) Multi-Jet Remap? ne1l Grande Punto 30 29-04-2007 22:42
(G) Remap or tuning box? Daver Grande Punto 2 19-07-2006 21:52
(G) 2.0 20v ReMap - Power increase? bulldog5046 Marea 41 16-02-2006 12:52
(T) Angel Tuning Remap darkcircuitUK Punto 11 27-05-2005 19:57
(T) Remap to 155 bhp and over siuron Stilo 23 27-04-2005 16:35
