The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 03-05-2007   #1
jetweed's Avatar
Trader Rating: (0)
Load capacity of cigarette lighters?
Hello there..
I'm driving to Rome and I'm one of the lucky ones with a boot cigarette lighter power socket..
I want to know what is the load capacity of the cigarette lighter power system? Would I kill the battery if I was to have a powered coolbox in the rear duelled with a hdd with a long usb lead to usb to blue &me ; my tomtom in the front and possibly duelling with a mobile phone charger...
What do you think?
Btw I'm gonna complain on Fiatforum's members behalf regarding the inconsistency of having a power socket installed in the boot.. Considering how cheap they are and how a necessity they are with a tyre compressor etc it seems crazy! I'll let you know how I get on..
Fiat Grande Punto M-Jet Sporting in Exotica Red : Skydome ; Climate Control ; Leather ; Parking Sensors ; Tyre Pressure Sensor ; Subwoofer
Absolutely Stunning! Guiguaro WELL DONE!
jetweed is offline
Old 04-05-2007   #2
sharkrider's Avatar
Trader Rating: (0)
Re: Load capacity of cigarette lighters?
Originally Posted by jetweed View Post
Hello there..
What do you think?
hmmmm *goes to look in my own boot for a power socket!!
well, the cigarette lighter (being a metal coil heated by current) will take a large current drain, so I'm sure running chargers/satnav ect is well below it's tolerances.... I'm not sure about the powered cool box, check out it's current draw, then check out the fuse for the cigarette lighter, that will give you the figures you need, if it's current draw is less than the fuse rating, you're fine
Current car: red GP sporting, 1.9 (158bhp, (147bhp at the wheels) and 314 lbs/ft )
last car: fabia vRS, 160bhp, 80k by the time I'd finished with it. Gone, but not forgotten.
sharkrider is offline
Old 04-05-2007   #3
Trader Rating: (0)
I'd be more worried about the car being able to supply enough power for all that and still keep the battery charged! Make sure you turn it all off when you stop the engine
Maybe you should connect it all up turn the lights on and leave the car idling for a while and see what happens, if the lights start to dim after a while your probably pulling too much.
I'd love to know how you get on though as I'll probably be doing very very similar come july 07
Fiat Panda's are a bit like cats, you think your the master but they think otherwise...
panda type thingy is offline
Old 04-05-2007   #4
sharkrider's Avatar
Trader Rating: (0)
arn't the cig lighter sockets turned off when you stop the engine? they are in mine...... your alternator should automatically adjust to supply the right current... if it cant cope, you should get a warning light... but the only times I've heard of this happening are with big ICE installs, where an uprated alternator, and an extra battery are usefull....
Old 04-05-2007   #5
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
You shouldn't have a problem with these, the cigarette lighters and power outlets usually have a rating of 20 amps and 180W so you should be OK if you stick below this. The alternator will be well up to keeping up with this as the power drain is about the same as having your lights on
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180, Mazda MX5 1.8i
allanhelen is offline
Fuel capacity and oil capacity inc filter topcat5 Doblo 1 07-03-2007 11:20
Multipla load area raven_nightmares Multipla 2 10-07-2006 22:33
car cigarette lighters thefishdude Leisure Lounge 13 02-01-2006 16:50
(T) Wiring Lights to run off switches, not plug into the cigarette lighter? MagnaMorbius Bravo / Brava 6 21-08-2005 18:15
(G) cigarette lighter arrel Punto 2 26-09-2004 18:27
