The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 30-04-2007   #1
sharkrider's Avatar
Trader Rating: (0)
squeeky noise (trapped mice?!)
hey all,
I'm getting a squeeky noise from the engine bay at tickover/v.slow manouvers...
related to engine speed not road speed, sound like an old car with a slightly loose alternator belt (though quieter, and not related to 'load' on the alternator [I tested this])
any ideas? or similar noises? everything appears to be working fine.... all fluid levels ect check out....
Current car: red GP sporting, 1.9 (158bhp, (147bhp at the wheels) and 314 lbs/ft )
last car: fabia vRS, 160bhp, 80k by the time I'd finished with it. Gone, but not forgotten.
sharkrider is offline
Old 01-05-2007   #2
Turbodiesel's Avatar
Trader Rating: (0)
Australia
Re: squeeky noise (trapped mice?!)
It's either just a squeaky belt, or there really are mice trapped in your engine
It might go away on it's own eventually, a lot of cars have squeaky engines when idling.
Turbodiesel is offline
Old 01-05-2007   #3
sharkrider's Avatar
Trader Rating: (0)
thanks for the reply... I was thinking I may be being a little paranoid.... another 180 miles yesterday, and still ok ! lol...
Old 02-05-2007   #4
Aresby's Avatar
Trader Rating: (0)
Aresby has donated! United Kingdom
I had a squeak from the clutch spring (more a quiet moaning noise, almost like a cow moo-ing) but WD40 cured it.
"There's no point going through life being a pessimist. It's probably not possible anyway"
Aresby is offline
Old 02-05-2007   #5
sharkrider's Avatar
Trader Rating: (0)
lol... mines deffo from the engine bay... and only at tickover/low revs, and only when cold.... hhhmmmmmm
Old 03-05-2007   #6
Trader Rating: (0)
Australia
Try spraying some WD40 in places you think it might be coming from. That stuff fixes any squeak
Old 03-05-2007   #7
sharkrider's Avatar
Trader Rating: (0)
may actually have a go at that, the more I investigate, the more it seems to be a rubber mounting that is squeeking with the movement ove the engine, it even does it when turning the engine over before it starts... but hardly at all at speed... a bit of grease is in order I think....
Old 03-05-2007   #8
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Dont spray on belt.
T14086 is offline
Old 13-06-2007   #9
Trader Rating: (0)
Have you figured out what was causing the noise?
I've got a GP 1.9, and it's started making the same noise in the same circumstances.
Mark S
Mark S is offline
Old 13-06-2007   #10
SNAP!
luvduvs's Avatar
Trader Rating: (0)
luvduvs has donated!
Mark S
Is it similar to these - http://www.fiatforum.com/grande-punt...-creaking.html, or http://www.fiatforum.com/grande-punt...t-pillar.html?
luvduvs is offline
Old 14-06-2007   #11
sharkrider's Avatar
Trader Rating: (0)
Mark S
it was fixed by the dealer a few days ago after I got worried because it was getting worse.... took him a while to find it, but 10 seconds to fix! lol... was a clip on the gear linkages that was not connected, he shoved it back in properly, and all is now fine and quiet
Old 15-06-2007   #12
Trader Rating: (0)
Thanks for that info. I do sometimes hear the squeak as I change gear, so it may well be the same problem that I've got.
The car's off to the dealer next week, so we'll see what they have to say.
Mark S
Mark S is offline
Old 16-06-2007   #13
captain chaos's Avatar
Trader Rating: (0)
Sharkrider, any idea where said linkage is. Is it something I could have a go at as my car has the same problem. Anything to save a trip to my dealer!
captain chaos is offline
Old 16-06-2007   #14
sharkrider's Avatar
Trader Rating: (0)
I saw 'em fix it, but didn't get under the ramp to get a close look, but its somewhere in front of the first 'box' on the exhaust, a liitle tricky to get to (above the exhaust) and to do with the gear linkages apparently...
best I can do... if you get under there and its the same prob, I'm sure you'll see something hanging loose......
Old 21-06-2007   #15
Trader Rating: (0)
The garage said the problem was due a gear cable not being tied down, which sounds pretty much like the problem Sharkrider had.
Mark S
Mark S is offline
Squeeky noise and ignition light on volxstu Lets Talk FIAT 1 24-01-2007 17:05
(T) Noise from the engine. TheCROW Bravo / Brava 3 06-04-2006 07:17
(T) continuous clicking noise wiper motor? HELP nickphonics18 Punto 2 13-02-2005 15:14
(T) Squeeky noise from rear HornetUK Stilo 7 02-12-2004 20:17
(G) squeeky noise from engine moshpit666 Uno 2 15-05-2004 16:03
