The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 14-04-2007   #1
Trader Rating: (0)
Arrow Dump Valve!??
hya fellas, has anyone lookd into getting a dump valve or actually had this done? its is one of the onli 2 mods i think i am going to do! Cheers peeps
DannyWestwell1986 is offline
Old 14-04-2007   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Dump Valve!??
on what engine?
custard is offline
Old 14-04-2007   #3
Black GP Sporting
minnnt's Avatar
Trader Rating: (0)
minnnt has donated! United Kingdom
Re: Dump Valve!??
i would have thought it would be for the 1.9 sporting...
tbh, if you're going to fit one, then i would fit a bov and blanking plate (has the 1.9 got a recirc valve???) so you get a varied noise, as the dv will only give one note...
minnnt is offline
Old 14-04-2007   #4
Trader Rating: (0)
Re: Dump Valve!??
sorry, 1.9 gp sporting
Old 14-04-2007   #5
Trader Rating: (0)
Re: Dump Valve!??
What's a bov and blanket plate?
Old 14-04-2007   #6
Black GP Sporting
minnnt's Avatar
Trader Rating: (0)
Re: Dump Valve!??
a bov is a blow off valve and the blanking plate will fit over the hole on the recirculating valve which will give a more wrc dump valve sound as oppose to just a 'dump' noise.
minnnt is offline
Old 14-04-2007   #7
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: Dump Valve!??
if the car has a recirc, changing to atmopsheric will more lilkely confuse the ECU. Guessing it uses a MAF sesnor to monitor the air flow, if you are dumping air to atmopshere that has passed through that sensor then the engine thinks it has more in there than it does and will cock up the fueling/timing.
arc is offline
Old 14-04-2007   #8
Black GP Sporting
minnnt's Avatar
Trader Rating: (0)
Re: Dump Valve!??
hence the blanking plate.
minnnt is offline
Old 14-04-2007   #9
arc
arc's Avatar
Trader Rating: (0)
Re: Dump Valve!??
you missed my point, re-read.
arc is offline
Old 14-04-2007   #10
Banned
Puntoboy's Avatar
Trader Rating: (0)
Puntoboy has donated! United Kingdom
Re: Dump Valve!??
VAG diesel engines hate atmos DV's. Hence why all the Cupra/vRS/TDI boys use uprated recircs.
Puntoboy is offline
Old 15-04-2007   #11
Black GP Sporting
minnnt's Avatar
Trader Rating: (0)
Re: Dump Valve!??
you missed my point aswell... re-read yourself!
minnnt is offline
Old 15-04-2007   #12
Trader Rating: (0)
Re: Dump Valve!??
Am I missing something here, but dont diesels have to use those gay electronically activated DV's?
Puntoboy is correct about the VAG lot having to use uprated recirc's. I had to do this on my old Cupra, and then to get the 'noise' you are probably after you will need to also add a metal CAI. (This is on petrol though, not diesel)
See HERE for more info on a diesel DV
Steve_R is offline
Old 15-04-2007   #13
Trader Rating: (0)
Re: Dump Valve!??
yes or no's then, should i consider a dump valve on my 1.9 sporting when i get it? Cheers
Old 15-04-2007   #14
<Team TD>
Bob in disguise's Avatar
Trader Rating: (0)
Bob in disguise has donated! United Kingdom
Re: Dump Valve!??
I see a red GP sporting 1.9 mjtd at guildford cruise before i got mine, which had a dump valve on it and it just sounded gash cause the mjtd aint exactly the quietest diesel engine, so just got the big rev of noise from the engine then a crappy little tish...
I wouldnt bother tbh and leave dump valves, etc to petrol turbos...
Bob In Disguise
Ex Fiat Owner
EX: Grande punto sporting
Former: Fiat Stilo 3 door
Former Former: Mk1 Punto 3 door
Bob in disguise is offline
Old 15-04-2007   #15
arc
arc's Avatar
Trader Rating: (0)
Re: Dump Valve!??
no, you are talking about plugging the old hole up with a plate - which is clearly something you need to do. my point was that by dumping air from the manifold that has already been through the MAF sensor you will confuse the ECU.
If say 300cm2 of air has passed through the sensor, and then you lift off - normally this is dumped from one side of the turbo to the other. With an atmopsheric dump valve, this air will dumped back to the atmopshere. As far as the ECU is concerned there is still 300cm2 of air as it knows it has a recirculating dump valve.
arc is offline
(G) Help With Fitting A Dump Valve... Rob-mint-mk1-uno Uno 3 28-10-2006 12:57
(G) dump valve Drinu Uno 1 24-09-2006 12:20
Dump Valve 1.9 Td Tipo calvins_tipo Tipo 10 10-09-2006 00:31
(T) hi im new which dump valve? lol bez440 Punto 3 12-04-2006 21:16
(G) Dump Valve Probs Dunc Maclean Uno 2 06-07-2004 04:42
