| I hope someone here can explain to me what I'm doing wrong. I have recently been given a new shape grand punto to drive. It has a "semi-automatic" gearbox and whenever I park it beeps at me like it is trying to warn me that I'm doing something wrong. I make sure that I put the gears into Neutral and put on the hand break but when I switch of the engine it beeps at me and the N (for Neutral) flashes on the daskboard display. What should I do? Thanks for any ideas.
| oh me gums! | Re: Auto Beeps When I Park i dont drive a gp but doesnt the manual tell you parking up procedure? | ||
| | #3 | ||
| Re: Auto Beeps When I Park Unfortunately I only have the Punto from a hire company and I was not provided with a manual. So if anyone reading this has one - can they please tell me what it says? :-)
| | #4 | ||
| can go much lower | Re: Auto Beeps When I Park don't auto's have a "P" gear for parking?
__________________ ![]() CinquePunto - Five Point Photography - Adam | ||
| | #5 | ||
| Re: Auto Beeps When I Park Yup. Normally 'P' is for parking...at elast it was in the few auto's I've had the misfortune to drive.
| | #6 | ||
| Forum Moderator | Re: Auto Beeps When I Park No P on dualogic just N.
| | #7 | ||
| oh me gums! | Re: Auto Beeps When I Park yeah but this is selespeed or duallogic or whatever its now called | ||
| | #8 | ||
| Forum Moderator | Re: Auto Beeps When I Park dual logic (Fiat) .......selespeed (alfa)
| | #9 | ||
| 5vp3r m0d | Re: Auto Beeps When I Park Hmm, so you like to leave your car in Neutral when you park? That is the problem, user error and the car is beeping at you to rectify it. The GP is just following correct procedures
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #10 | ||
| Forum Moderator | Re: Auto Beeps When I Park dualogic just changes gear for you at touch of lever (steering wheel controls in selespeed alfas) or automatically in auto mode...still gotta use your handbrake................if you pass driving test in dualogic can you drive a manual or auto only
| | #11 | ||
| 5vp3r m0d | Re: Auto Beeps When I Park The problem is the fact he wants to leave it in neutral - when you park, and the car is beeping, just knock it into reverse or 1st - the beeping soon stops, and then you can leave the car SAFELY, with the handbrake on as an added safeguard.
| | #12 | |||||
| SNAP! | Re: Auto Beeps When I Park
When starting the car just make sure you step on the brake and shift it back to N before you turn the ignition, otherwise it'll beep again Beeping means you're doing something it doesn't like
| | #13 | ||
| Banned | Re: Auto Beeps When I Park You sure it it's parking sensors?
| | #14 | ||
| | #15 | ||
| fiat 131 auto box mount | rockhouse | Other Fiats | 1 | 18-02-2006 22:03 |
| | takracing | Marea | 0 | 07-07-2004 17:40 |
