The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 31-03-2007   #1
Alex_gregory_uk's Avatar
Trader Rating: (0)
Sidelight bulbs
Has anyone managed to replace their sidelight bulbs with some LED ones that are more xenon coloured? I have tried two different types and because they use less power they flash, and the warning inside the car comes on to check the bulbs. Can anyone help?!
Alex_gregory_uk is offline
Old 31-03-2007   #2
Trader Rating: (0)
Re: Sidelight bulbs
Am guessing that the warning system works on measuring the current consumption of the sidelight bulbs
When a tail ight bulb (21W) is on it draws something like 1.75A
So when a bulb blows it goes open circuit, 0A current flows and it can sense the bulb has blown.
LED's typically draw 10s or 100s of milliamps, say from 50mA (0.05A) so when they are on it appears to the sensor that the bulb has blown.
The only thing I can suggest is to wire a resistor in parallel with LED. From the point of view of reducing power consumption this defeats the whole idea!
Has the added drawback of
- hacking your loom (italian cars<>electrical problems!! )
- you need largish resistors and have a fair amount of heat to get rid of
If you can live with the warning then I guess that is the best bet!
hth
BigAde is offline
Old 31-03-2007   #3
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Sidelight bulbs
5W
T14086 is offline
Old 08-05-2007   #4
Joe473's Avatar
Trader Rating: (0)
Re: Sidelight bulbs
Here are my new sidelights...
When on alone they show blueish, but when Dipped headlights are on, they are completely unoticable!
Joe Whitelock
Joe473 is offline
Old 08-05-2007   #5
RAC 500W
RichC's Avatar
Trader Rating: (0)
RichC has donated! United Kingdom
Re: Sidelight bulbs
Yours look very similar to my Philips Blue Vision bulbs. When the headlights are on it just gives a nice blue edge to the light but not too much that it looks stupid.
Rich
RichC is offline
Old 11-05-2007   #6
SNAP!
luvduvs's Avatar
Trader Rating: (0)
luvduvs has donated!
Re: Sidelight bulbs
Looks rather ghoulish.. (but nice )
luvduvs is offline
Old 11-05-2007   #7
smifton's Avatar
Trader Rating: (0)
Re: Sidelight bulbs
ghoulish is good!
smifton is offline
Old 12-05-2007   #8
Black GP Sporting
minnnt's Avatar
Trader Rating: (0)
minnnt has donated! United Kingdom
Re: Sidelight bulbs
if you have replacement standard type sidelights then you will be fine, but if you replace them with l.e.d.s then you will need a load resistor to keep the current stable at a higher voltage as oppose to it thinking one has blown due to the low current they draw. it's also the case with the rear number plate lights and if you want to replace the rear indicators with l.e.d. unit this will also flash up the warning on the screen even though they flash normal on the outside, the inside is going crazy!!!!!
minnnt is offline
Old 12-05-2007   #9
smifton's Avatar
Trader Rating: (0)
Re: Sidelight bulbs
...God i Hate electronics....quite possibley my weak point on cars.
smifton is offline
Old 14-04-2008   #10
rosshutchie's Avatar
Trader Rating: (0)
rosshutchie has donated! United Kingdom
Side light bulbs
Im just wondering, has anyone changed the sidelight bulbs on there GPS? I put in some 'Prism LED White bulbs' to match my Xenon look headlights and the sidelights immediately started to flash and it came up on the dash a 'light fault'. Does that mean i cant chage the sidelight blubs to anything else apart from the standard yellow ones?
rosshutchie is offline
Old 14-04-2008   #11
Smally's Avatar
Trader Rating: (0)
Smally has donated! United Kingdom
Re: Side light bulbs
it means that the prism leds use less power the computer senses that less power is being used so thinks a bulb is out. some led bulbs have a built in resistor so that they use the same power as a standard bulb thus not causing a fault.
all normal bulbs should work fine.
that is my basic understanding of things
\/ Click \/
Smally is offline
Old 14-04-2008   #12
NFFC
tommy_8884's Avatar
Trader Rating: (0)
tommy_8884 has donated! United Kingdom
Ok the problem is:
The GP is fitted with a bulb error/fault detection system. This detects when a bulb has gone and warns the user via the dash display. In simple terms it monitors how much wattage is going through the system. LED lights use less than mormal bulbs and therefore causes the system to think there is a fault. All the lighting systems in the GP with the exception of the main/dipped beam and internal lights have this system.
You can use resistors to fool the system. Like these : http://www.autobulbsdirect.co.uk/home.php?cat=656
PS: feel lucky the GPS has this system 2-3 years ago it waas only on mercs and alike. Mind you i think the most important bulbs are the dipped/main and for some reason ot does not tell you about tehse
57 Plate GPS Multijet 130, Black
Red Painted Calipers, Footwell LEDs, Reverse Parking Sensors, Vibe Front Components, 12" Active Vibe Sub
tommy_8884 is offline
Old 15-04-2008   #13
129.1db loud!!
loudpunto's Avatar
Trader Rating: (0)
loudpunto has donated! United Kingdom
Re: Sidelight bulbs
i have the same ones in mine they came free with the headlight bulbs i bought! lol
GP Active 1.2 8v Un-official Stripes Edition, custom made 6x3 stainless steel backbox, 17" Boss XL400s, Kenwood USB CD Player, Hertz front comps, Cerwin Vega 12" Sub, Jetstream Amp, gloss painted drums, Eight Ball decal stripes, vinyl front end and custom made FF no plates and FF Stickers, day running lights and footwell lights and 129.1db!
loudpunto is offline
Old 15-04-2008   #14
Punto.Jack's Avatar
Trader Rating: (0)
Re: Sidelight bulbs
How do you change them on a mk2 fiat punto?, i swear you can only get to them by pulling off the covers but i think they will snap off!
2001 1.2 Mk2 Silver Punto + Induction kit, Hertz & Vibe Audio + 15" Wolfrace
Originally Posted by gaz.d View Post
i had a pic somewhere of what a cock is but i cant find it
Punto.Jack is offline
Old 15-04-2008   #15
129.1db loud!!
loudpunto's Avatar
Trader Rating: (0)
Re: Sidelight bulbs
if you have a look in the punto section i'm sure there will be someone that has had the same problem!
(G) ultra xenon bulbs ger Punto 1 02-11-2006 20:47
(G) Replacement bulbs for HID look, opinions and advice kritip Cinquecento / Seicento 7 03-07-2006 09:19
(T) New bulbs and few probs/questions. Horney Cinquecento / Seicento 8 06-12-2005 15:49
(G) MK2 sidelight bulbs ger Punto 2 15-11-2005 01:01
(G) Which new bulbs?! jamie86 Cinquecento / Seicento 16 17-11-2004 18:28
