The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 22-12-2006   #1
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
Question In the process of fitting front fogs to my GP
Just in the process of fitting some fog lamps to my 1.2 Active Fiat haven't made a kit / don’t list replacement fog lamps in their dealers part list yet
Anyhow as i nearly had a head on yesterday morning by some dozy b@$t@rd on my side of the road in the thick fog i decidet to fit some as temporary stop gap till i can get my hands on some genuine fiat lamps. I bought a set of cheap Projector fog lamps and set about butchering my GP's blanking plates, So far so good only took a "few" hours to make a bracket and to mount them. I decided to drill the blank plate at least if i had made a balls of it a replacement shouldn’t cost too much.. When i get my hands on some proper fiat lamps the wiring will be in..
Just need to Wire them in now via a relay, they look ok and managed to align them in the dark tonight via connecting directly to the battery (via a fuse)
Does any one know the sidelight wire colour??
Otherwise I’m half tempted to take the switching feed off the tow bar electrics to avoid hacking into the sidelights in the engine compartment
Any how here a couple of photos…..
http://uk.pg.photos.yahoo.com/ph/mon...e2.jpg&.src=ph
what do you think??
Andy Monty is offline
Old 22-12-2006   #2
Trader Rating: (0)
Re: In the process of fitting front fogs to my GP
I like them.....I think they look surprisingly good....nice job.
Superboy is offline
Old 22-12-2006   #3
smurfhead's Avatar
Trader Rating: (0)
they look smart!
Gaz
smurfhead is offline
Old 22-12-2006   #4
Andy Monty's Avatar
Trader Rating: (0)
All done.
I used a Ring Remote control Relay kit to save having to go fishing through the bulk head and having to mount a switch (yes im lazy) but it was a piece of p155 to wire the only thing is the Relay kit is "E" marked but there is no Internal warning light to let you know the front fogs are on (however it does turn off when the sidelights are turned off) doubt it will be an issue untill MOT time...
didnt realise they where Yellow Tinted but they stand out
all that i need now is a few cable ties to tidy the wiring up
Old 22-12-2006   #5
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Look ok mate
Fog lights are available but bit expensive.
Going through bulkhead is easy by the way,handy for a consul mounted switch
T14086 is offline
Old 23-12-2006   #6
Andy Monty's Avatar
Trader Rating: (0)
T14086
whats the easyest point to get through the bulkhead??
i originally picked up a Ring relay with a square rocker switch but i didnt fancy butchering the dash board plus i'd have needed to find an earth for the light in the switch and the relay wasnt sealed
I had a kit that i wired some fogs in my KA to which was a slefcontained self adhesive swith which had a red and green led inside but aparently they have stopped making them.
any one know the part numbers for the replacement left and right front foglamps?
Old 23-12-2006   #7
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Andy,easiest way I have found is through the large grommet under scuttle panel on the near side.This comes out nicely behind the glovebox (best to remove) make sure you use some sealent on the grommet afterwards just incase of water penetration.I normally mount a 'dinky' round black switch (with internal red LED) in the centre consul...looks good
Dont forget to fuse live to the fog lights
T14086 is offline
Old 23-12-2006   #8
Andy Monty's Avatar
Trader Rating: (0)
Thanks for that
And it is fused on the live...
Old 24-12-2006   #9
jameswhit's Avatar
Trader Rating: (0)
They look good mate, have thought about getting some front fogs for my car after the trouble I've had round here recently.
Being stuck out in the middle of nowhere means that it is often foggy down the country roads!
jameswhit is offline
Old 28-12-2006   #10
Forum Moderator
T14086's Avatar
Trader Rating: (0)
In ressponse to this thread I have done a quick guide.......
http://www.fiatforum.com/grande-punt...og-lights.html
Please feels free to read through & point anything out,hope this is of help.
T14086 is offline
Old 28-12-2006   #11
Andy Monty's Avatar
Trader Rating: (0)
Nice guide T14086 Just to add another word of warning watch the Blanks if you intend to drill them out for after market lamps the radiator suport could fowl the back of the lamps (mine only just miss)
Old 28-12-2006   #12
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Cheers for that ,suppose best to remove them first but unlike the mk2 puntos the 'blanks' are a real tight fit.....I can see a few bruised knuckles happening
T14086 is offline
Old 03-02-2007   #13
jawkithenoo's Avatar
Trader Rating: (0)
jawkithenoo has donated! United Kingdom
smart job,they look a lot better than i was expecting.
jawkithenoo is offline
Old 04-02-2007   #14
Trader Rating: (0)
Fog lights -dealer fit
Can anyone tell me if it is possible for dealer to fit genuine fog lights in an Eleganza or is some of the circuitry missing? I apologise if this has come up elsewhere but I am unable to find it if it has.
sveleganza is offline
Old 04-02-2007   #15
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: Fog lights -dealer fit
T14086 is offline
(G) Mk 2 Front Fogs Lights jay_punto Punto 3 05-03-2006 17:49
Front bumper and o/s front wing needed? Kerios Barchetta 1 06-06-2005 21:07
(S) Sei Abarth Bumper - Front Fogs Adamski Cinquecento / Seicento 12 25-04-2005 10:30
(T) Help needed - Fitting front wing JonT Bravo / Brava 2 17-01-2004 02:18
(S) Fitting a front splitter Jonna83 Cinquecento / Seicento 0 28-02-2003 04:22
