The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 08-05-2008   #1
My punto has gaydar.
1mmortal's Avatar
Trader Rating: (0)
1mmortal has donated! United Kingdom
New 18"s - wheel bolts or wheel studs
Can someone please explain to me the difference between "wheel bolts" and "wheel studs"?
I was looking at some 18"s for my GP Sporting, and told that the GPS has "wheel bolts" - can I get around this by getting a new set of bolts?
edit: this topic probably best suited in the technical section.
Thanks in advance,
If i had a hammer, there'd be no more folksingers
'06 GP 1.9 Sporting - ERotica Red only 12K miles - I need one 17" FIAT Alloy still - anyone got one?
1mmortal is offline
Old 08-05-2008   #2
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Luke M has donated! United Kingdom
Re: New 18"s - wheel bolts or wheel studs
wheel bolts are bolts that screw into the hub. studs is where a threaded bar comes out of the hub and a nut screws onto that.
if your getting new wheels i would recommend getting the correct bolts with the correct seating for the wheels. if you get the wrong seat it will create pressure points and sheer the bolt.
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline
Old 08-05-2008   #3
Will31st's Avatar
Trader Rating: (0)
nothing, theyre just differrent names. unless u mean wheel nuts and wheel studs, if thats the case nuts are just the ring bit(the threads will already be on the wheel hub) studs\bolts are what the gp has and they are the long screws that go thru the wheel and into the hole inside the hub.
'06 GP 1.2 Active Psychadelic Azure.
17" Team Dynamics Puma's, 7" DVD Player, 10" Vibe Evo, 12" Vibe Evo V.2, 4xVibe SE-K10's 2xVibe SE-K60's, 2xVibe QB69's, Vibe Slick A3 amp.
Will31st is offline
Old 08-05-2008   #4
Dislikeskeyboardwarriors
Steely's Avatar
Trader Rating: (0)
Steely has donated! United Kingdom
whats the PCD on gp sportings?? might need wobblys
Steely is offline
Old 08-05-2008   #5
1mmortal's Avatar
Trader Rating: (0)
OK still a bit confused - i think i know what you're both getting at - could someone mspaint me a picture or point me to a photo of teh GPS's screws that go into the hub (just to be crystal)?
TIA,
1mmortal is offline
Old 08-05-2008   #6
1mmortal's Avatar
Trader Rating: (0)
I think its 100, but could be 98. In my handbook (which i suppose is standard for all GPs it says 100 at the bottom...?
Anyone know the definitive answer to this?
1mmortal is offline
Old 10-05-2008   #7
Smally's Avatar
Trader Rating: (0)
Smally has donated! United Kingdom
its 100
\/ Click \/
Smally is online now
Old 10-05-2008   #8
Br00m!
Stripes's Avatar
Trader Rating: (0)
Stripes has donated! United Kingdom
4x100 ET38 offset iirc.
Stripes is offline
(G) how do i know which of the four wheel bolts holds my wheel trim on? fr8ggle Cinquecento / Seicento 10 01-02-2008 17:25
(G) punto wheel studs dave2110 Punto 10 14-11-2005 20:19
(T) ALLOY WHEEL "WOBBLY" BOLTS carlb1027 Punto 17 29-08-2005 22:58
Locking Wheel Studs ts86net Lets Talk FIAT 1 23-12-2003 03:10
