The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 05-05-2008   #1
Trader Rating: (0)
hootie121188 has donated!
How to remove grille and rear badge?
Hi
Stupid question...but how do i remove the front grille and the rear badge...is it easy?
cheers
Grande Punto 1.4 Active Sport in Crossover Black
Red Brake Calipers, Philips Blue Vision, Red Grill surround, New Bulbs all round....more to come!
hootie121188 is offline
Old 05-05-2008   #2
Smally's Avatar
Trader Rating: (0)
Smally has donated! United Kingdom
Re: How to remove grille and rear badge?
http://www.fiatforum.com/grande-punt...l-removal.html
but y do u want to do this?
n if you wanna take the punto badge off just pic it off thts what i did. or heat it up n pull it off wid floss.
\/ Click \/
Smally is online now
Old 06-05-2008   #3
TJet powaaaaaaa
punto_matt's Avatar
Trader Rating: (0)
punto_matt has donated! United Kingdom
Which rear badge? If you mean the punto one just heat it up and push a credit card or something similar behind it to get it off. If you mean the fiat one then i presume there is a recess in the boot and it is bolted through to you would need to go to a body shop get the recess fillered/ a plate welded in to make it level and then get the boot resprayed to get rid of the rear fiat badge.
punto_matt is online now
Old 07-05-2008   #4
Got DISH?
Jamie's Avatar
Trader Rating: (0)
Jamie has donated! United Kingdom
rear fiat one is stuck on too recess and holes tho
Jamie is offline
Old 07-05-2008   #5
Lee.Johnston's Avatar
Trader Rating: (0)
Wow that is confusing! So can you take the rear badge off then or not? Is there any holes? Im just confused How easy is the process and what do you use to heat the badges?
Lee.Johnston is offline
Old 07-05-2008   #6
Smally's Avatar
Trader Rating: (0)
the fiat one you can take off but you will be left with a recess that the badge was sat in. if you just wanna change it with another one it wil be fine.
if you want it debadged then u will need someone to weld a plate in the grind it down then respray the boot.
the punto one comes off with ease just pick off or heat then credit card it off.
\/ Click \/
Old 07-05-2008   #7
Got DISH?
Jamie's Avatar
Trader Rating: (0)
punto badge = stuck on/no holes
fiat badge = stuck on/holes and recess
Jamie is offline
Old 07-05-2008   #8
TJet powaaaaaaa
punto_matt's Avatar
Trader Rating: (0)
Heat it up with a hair dryer or heat gun to loosen the clue then slide a credit card or similar behind it to get it off. Then pick the glue off.
(S) Multijet Grille badge MHRAR Grande Punto 2 04-11-2007 17:54
Fiat Badge Mk1 panda Grille Sprox Panda (Classic) 39 13-01-2007 22:53
