| Footwell lights I have got some LED strips to go in the front footwells and was wondering if anyone knew where I could join the cable to. I want to do them off the interior light and would be able to follow the cable down the pillar and into the dash and connect there, but am just wondering if anyone knew where the cable was so I don't have to take the trim off to work out where it goes. Thanks in advance. Alex
__________________ ![]() White GP sporting 1.9, Skydome roof, parking sensors, debadged, red calipers, lowered on Eibach sportlines, black gloss alloys, clear rear fog light, LED numberplate lights, MTEC sidelight bulbs, Silvervision indicator bulbs, black vinyled front, merkur upper and lower grills. | |||
| Re: Footwell lights You can Wire it into the headunit apparently, although I havent tried myself. My ideal place was the interior light as well.
__________________ Fiat GP 1.4 Active sport in crossover black | |||
| | #3 | ||
| Re: Footwell lights The benefit of the interior light is it has the automatic dimmer built in so all the interior lighting will dim at the same time. So I'll take the feed from the interior light when I can locate the right wires!
| | #4 | ||
| Its a Sporthing | Re: Footwell lights sounds abit dodgy to me, i wouldn't even tink about touching the electrics, could cause all sorts of faults in the future.
__________________ GRANDE PUNTO SPORTING T-JET 120 | ||
| | #5 | ||
| NFFC | Re: Footwell lights wire in parallel to the wires behind the courtesy light (if you have a sporting the wiring is quite complex cos of 2 bulbs and lots of switch positions). Not tried it but there is no reason why that wont work. Im sure you could feed it down from there without having to remove any trim. Just takes some niffty tucking.
__________________ ![]() 57 Plate GPS Multijet 130, Black Red Painted Calipers, Footwell LEDs, Reverse Parking Sensors, Vibe Front Components, 12" Active Vibe Sub | ||
| | #6 | |||
| Re: Footwell lights
__________________ G.P. Dynamic Sport 1.4 16v 5Door. Chemical Grey. | ||||
| | #7 | ||
| NFFC | Re: Footwell lights it does have 2 bulbs, i took the light appart last night to see what type of buls were in there, there are two switches (one left, one right) each with 3 positions. To get them both on always you switch the left one on, to get the right one only you switch the right switch while the left is switched, to get the left you have to switch the left and the right, to get them both on auto you switch them both to the middle and so on. As i said, rather complex ( i probably got those combinations wrong). If you were going to wire a light off it you would have to chose which bulb you wanted it to run off i guess.
| | #8 | |||
| Re: Footwell lights
__________________ G.P. Dynamic Sport 1.4 16v 5Door. Chemical Grey. Last edited by BigAl54; 29-11-2007 at 20:36. | ||||
| | #9 | ||
| Top Dog | Re: Footwell lights Do you GP guys not have a cig lighter/ 12v power source to tap into? | ||
| | #10 | ||
| Re: Footwell lights there is a faglighter but its switched with the ignition...
| | #11 | ||
| No more heroes anymore. | Re: Footwell lights I am saying nothing
| | #14 | ||
| Re: Footwell lights I wondered how long before the negative comments started!!!! I am following the footsteps of minnnt who I think was done some nice interior lighting. I haven't had chance to look into it yet but will put some pics up when I have done it.
| | #15 | ||
| Its a Sporthing | Re: Footwell lights lol not negative comments, we were just saying that we wouldn't do it to our GP, as if a fault occured you can say bye bye to your warranty, electronics is a dodgy area to be fidling with, unless you know what you are doing of coarse.
| | efrules | Stilo | 34 | 23-05-2006 10:08 |
| | evol1 | Punto | 4 | 25-04-2006 10:18 |
| | namb | Cinquecento / Seicento | 3 | 20-02-2005 18:00 |
| head lights | ryan_welsh | Lets Talk FIAT | 7 | 23-01-2005 23:26 |
| | HornetUK | Stilo | 9 | 20-12-2004 20:30 |
