| changing bulbs i just done it. just wanted to give some advice - although this may seem obvious. remember how the bulb fitted in, including how the clip went. take apart slowly so you can understand how the bulb and holder fits through the metal latch. take your time and be patient. as condescending as this is, i tried rushing and almost f'ed it up! and got in such a mood! prepare time, its not a 5 min job unless youre an expert. took me almost 30 minutes just to do one side! i recommened doing this tho, as the results are great and a very cheap enhancement. thanks to all those who posted previously - it gave me help. Sam
| Re: changing bulbs What did you change the bulbs to??
| | #3 | ||
| Forum Moderator | Re: changing bulbs which bulbs
| | #4 | ||
| Re: changing bulbs
| | #5 | ||
| Forum Moderator | Re: changing bulbs LOL............if 'bell' is talking about headlight bulbs they take seconds to change
| | #6 | ||
| RAC 500W | Re: changing bulbs
__________________ | ||
| | #7 | ||
| Forum Moderator | Re: changing bulbs Pull of rubber cover,feel the metal retaining tag & push/move to right & it springs back.Renew bulb & refit in reverse.Probably about easiest bulb you can change....DID YOU HEAR THAT STILO OWNERS
| | #8 | ||
| Straight outta H-ton! | Re: changing bulbs Just did the indicator bulbs, sidelights and dipped beams. Put in Philips Silver Vision indicators and Philips BlueVision slidelights and dipped. Wasn't too difficult but the guides on here helped a lot - the manual is a wee bit vague.
| | fiatstilo3doororiongrey | Stilo | 1 | 10-11-2006 22:03 |
| | stilophil | Stilo | 15 | 30-04-2006 01:11 |
| | darkcircuitUK | Punto | 14 | 09-05-2005 16:31 |
| | ~Lee~_pUnTo_ | Punto | 2 | 21-02-2005 14:09 |
| | bhinderharminder | Punto | 16 | 17-02-2005 19:19 |
