The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Grande Punto
Old 11-06-2007   #1
captain chaos's Avatar
Trader Rating: (0)
Changing Your Indicator Bulbs Sir?
Right O, Just swapped my indicator bulbs out for the mirrored philips type PY21W.
TBH its a quick, cheap and effective MOD.
Anywhoo below is a step to step for those a little bit scared or just those of you who are a bit nosey!
So first things first, lift the locking lug to open your wheel arch access point.
Place your hand inside and you will feel the indicator housing. Turn it to the left and the bulb will remove...
Replace the bulb with your new shiney one and slam that bad lad back into your motor. Making sure to close the wheel arch flap when done lol.
Then you will have the following:-
captain chaos is offline
Old 11-06-2007   #2
damaz89's Avatar
Trader Rating: (0)
Re: Changing Your Indicator Bulbs Sir?
nice! cud u take a pic of the lights on at night because im tinkin of getin them just wana know wat dey look lyk!
damaz89 is offline
Old 11-06-2007   #3
Got DISH?
Jamie's Avatar
Trader Rating: (0)
Jamie has donated! United Kingdom
theyre indicator bulbs, they're the same in the daytime
Jamie is offline
Old 11-06-2007   #4
y is saving so difficult?
jamesgamby1989's Avatar
Trader Rating: (0)
jamesgamby1989 has donated! United Kingdom
they don't indicate a different colour so they would not be visible at night.
1.2 gp, chemical grey, all windows tinted, alpine headunit, fusion woofers, vibe tweeters, interior neons, xenon bulbs, blue sidelights, rainbow indicators, momo handbrake, induction kit, debadged boot, sony xplod sub and amp,personalised number plate, momo gear knob, punto black side stripes first in world, black lexus lights
K+ N INDUCTION KIT FOR SALE
jamesgamby1989 is offline
Old 12-06-2007   #5
SNAP!
luvduvs's Avatar
Trader Rating: (0)
luvduvs has donated!
I must be missing something - if its the same then why have them changed?
Or is this for when its blown and needs replacing?
luvduvs is offline
Old 12-06-2007   #6
brickdog's Avatar
Trader Rating: (0)
The bulbs Capt. Chaos has installed are designed to look silver when unlit while still giving the normal orange colour when lit.
This means the silver bulbs blend into the light array and don't stick out giving the headlight the "fried egg" look.
If you fancy a set I found them for just over £10 delivered on eBay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=002
A bargain for what I think is a simple but effective refinement to the look of the car.
brickdog is offline
Old 12-06-2007   #7
RAC 500W
RichC's Avatar
Trader Rating: (0)
RichC has donated! United Kingdom
Definately a modification worth doing. Its so simple yet it makes a big difference in my opinion.
Rich
RichC is offline
Old 12-06-2007   #8
Trader Rating: (0)
hay, thanks for the nice guide!
maybe a silly Q: the hatch for gaining access to the indicators - can you also replace your headlight bulbs by the same method?
thanks in advance.
bell13 is offline
Old 12-06-2007   #9
RAC 500W
RichC's Avatar
Trader Rating: (0)
thanks in advance.
There is only a hatch on the drivers side, you can reach the catch quite comfortably on the passengers side so there is no need for one. Headlight are just as easy to change although there is a little latch that tends to be a bit awkward when putting it all back in.
Ill reply to your PM in a couple of mins by the way, not ignoring you .
Rich
RichC is offline
Old 12-06-2007   #10
Trader Rating: (0)
i fitted both my indicator bulbs in the same way as shown above through the latch. when i changed my headlight bulbs i opened the bonnet and then removed the plastic cover, its all described very clearly in the manual how to change all of the bulbs etc.
Old 12-06-2007   #11
Trader Rating: (0)
yeah.
im definatly such an idiot.
headlight bulbs are somethng that might need to be changed DUH!
thanks for your response
bell13 is offline
Old 12-06-2007   #12
Trader Rating: (0)
Just replaced my headlight bulbs with the Philips H4 80% brighter bulbs.
For those that have not done this yet do it.
not seen them on at night but tested the lights with one original and one philips and there is a massive difference!
Friend of mine has a GP but is out the country at the moment when he gets back I will take a piccy at night showing the diff between the two.
To change the bulbs,
Open bonnet
Remove the rubber plastic circular bung to the rear of the light.
Stick your hand in and remove the black plastic plug at the back of the light (Just pulls off)
Then feel for a metal clip this pushes in and to the right to unlock the light bulb itself.
Remove bulb and place new bulb in its place making sure you dont touch the glass of the bulb (Will kill the bulb with the grease in your skin)
Push the clip back over the bulb to hold in place (latches back the way it came off)
Replace rubber bung.
Jobs a good un
Old 12-06-2007   #13
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
are those Silvered indicator bulbs "E" marked???
Lidl have sets of bulbs in for £3.99 this week either blue or +50% brightness put some blue ones in the headlamps (H4) and front fogs (H1) a much whiter light compaired to the original yellowy halogen and they are "E" marked should keep any over enthusiastic MOT or copper happy...
Andy Monty is offline
Old 12-06-2007   #14
Trader Rating: (0)
Be careful to ensure that that they are UV Quartz glass in your bulbs. Stops em buggerin your plastics in your lamps.
Also yes there EU alright. Philips make matey
Old 13-06-2007   #15
Andy Monty's Avatar
Trader Rating: (0)
Yep they are UV cut
might have a look at those then since they are E marked dont want to give the car insurance or another driver the excuse if im unfortunate enough to have an accident
Avoid Speeding Tickets By Changing Lanes Rampage94 Leisure Lounge 9 16-10-2006 21:08
(G) Advice on Changing front brake pads Peter 171 Punto 1 03-10-2006 22:37
changing cambelt 2.8 laikaman Ducato 3 03-07-2006 22:57
changing the front speaker wire Dan_55 I.C.E 6 01-01-2005 20:28
