The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Upgrading your speakers manual.<!-- google_ad_section_end -->
Published by jamesgamby1989
14-01-2007
Post Upgrading your speakers manual.
Ok to first fit the door speakers in the front you have to remove the door panel, it seems a disaster but is not very hard. there are 5 pozi screws at the bottom of the door which should be taken out and then two 5mm allen key holes under the handle by the window switch, and one more behind a plastic cover by the door handle.
Once all removed you have to pop it off at the sides and bottom from its clips. once removed you will see the speaker. first you un-plug the lead going into the speaker, then using a screwdriver prong the speaker out, im sure it does not matter if it is ruined unless you want to put them back at a later stage but mine came out fine.
I then screwed the replaced woofer into the actual door panel that has been removed and the cut the wires and put them together and covered them with electric tape. the same is then done with the tweeter except i put the tweeter the other side of the door and threaded the wire through, to ensure that the tweeter is fitted properly you should use a bracket behind the tweeter and tighten it so it stays in place, all you then have to do is put the door panel back as it was before.
Repeat for the other side & job done
Any other questions just pm me or write in this thread.
here you go moderator and my prize??????
Article Tools
The following user says "Thank You!" to jamesgamby1989 for this useful post:
Boxer_BertDUB (09-08-2008)
Old 14-01-2007   #1
ate too much
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Upgrading your speakers manual.
very nice however you seem to have misread the post.
we have a guides section.
this is where you were intended to put the guide.
pictures help a lot as well
removed so the flufftards can dry their eyes
Want +20BHP for £2?
do not click this link!!!!
custard is offline
Old 29-01-2007   #2
Zaxos_GP's Avatar
Trader Rating: (0)
Greece
Question Re: Upgrading your speakers manual.
could you tell me what is the size of the front speakers at gp?
<a href="http://xs.to"><img src="http://xs311.xs.to/xs311/07051/ypografi.jpg" title="Free image hosting powered by xs.to"></a>
Zaxos_GP is offline
Old 07-03-2007   #3
y is saving so difficult?
jamesgamby1989's Avatar
Trader Rating: (0)
jamesgamby1989 has donated! United Kingdom
16.5cm, i think that is it if i can remember, but it says in the manual.
1.2 gp, chemical grey, all windows tinted, alpine headunit, fusion woofers, vibe tweeters, interior neons, xenon bulbs, blue sidelights, rainbow indicators, momo handbrake, induction kit, debadged boot, sony xplod sub and amp,personalised number plate, momo gear knob, punto black side stripes first in world, black lexus lights
K+ N INDUCTION KIT FOR SALE
jamesgamby1989 is offline
Old 23-04-2007   #4
Trader Rating: (0)
hi there do u know if you can fit rca leads to run an ampt of the standard stereo in my grande punto or will i have 2 buy a new headunit and is there a cable i can buy so i can use the buttons on the stearing wheel for the radio any help would be very helpfull
shootingstar40 is offline
Old 30-04-2007   #5
Trader Rating: (0)
check the grande punto section about the standard headunit as a lot of people ask about that but i am not too sure, and the steering wheel controls will be lost when changing headunit but i am sure that there will be an adapter come out for the controls soon.
Old 16-07-2007   #6
Trader Rating: (0)
StuGP has donated! United Kingdom
Try out http://www.connects2.com, they have an AUX out adaptor there for Blaupunkt head units. I'm thinking of getting the same, my old megane had a cracking sub install in the boot and i miss it, but i've not had my GP that long so i want to keep the head unit. Hope that helps
StuGP is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Upgrading Speakers & Tweeters Rich Stilo > Technical 36 14-09-2007 23:19
Upgrading Doblo speakers Blythe Doblo 2 08-04-2007 20:32
What is the size of Marea's front door speakers? ibopasa Marea 5 12-03-2007 16:35
Upgrading your speakers manual. jamesgamby1989 Grande Punto 4 14-01-2007 21:56
Upgrading speakers with standard headunit chris_scotland I.C.E 3 03-08-2006 17:50
