Published by T14086 28-12-2006 | |||||||||||
| . | Re: Fitting front fog lights im buying the parts for this mod now so whats the voltage of the relay and switch? thanks Smally
| | #4 | ||
| Forum Moderator | Re: Fitting front fog lights I use genuine fiat lights/fittings and aftermarket switch(12v) and standard relay.
| The following user says "Thank You!" to T14086 for this useful post: | ||
Smally (22-12-2007) | ||
| | #5 | ||
| | #6 | ||
| The following user says "Thank You!" to Andy Monty for this useful post: | ||
| | #7 | ||
| Re: Fitting front fog lights I need to replace my front fog light (smashed it on a kerb ).Your guide is very useful T14086 - but I'm not 100% sure if it's just as simple as unscrewing the old and plugging in the new. Can you clarify please?
| | #8 | ||
| Forum Moderator | Re: Fitting front fog lights replacing original fog light? easy...3 screws to remove light,unclip electrical connector at rear...refit in reverse order,job done
new2fiat (07-02-2008) | ||
| | #9 | ||
| Re: Fitting front fog lights Nice one, thanks...I'll have a look at the weekend and give it a go ![]() One more question (and I know I could go and have a look but it's dark!) - do I need a special screwdriver? If so, what sort is it please? Cheers N2F
| | #10 | ||
| Forum Moderator | Re: Fitting front fog lights Its a torx or allen key..cant remember which (torx 40?)
| | #11 | ||
| Re: Fitting front fog lights Ok, cool....thanks!
| | #12 | ||
| Re: Fitting front fog lights Can you please clarify. If your car is not already fitted with front Fog Lights. are there mounts on the bumper when you remove the little black covers? Just when I went to Fiat and asked them about it they said, no. Then tried to say your would need a new bumper, Yeah right! RIGHT ?
| | #13 | ||
| Forum Moderator | Re: Fitting front fog lights see page 2 Start off by removing the blanking plates where the lights fit into,these need a firm push 'in the way' as they are retained by strong retaining clips.
| | #14 | ||
| Re: Fitting front fog lights The mounts are on the fog lamp brackets there is no separate inserts or mounting plates needed.. there is a Hole above the foglamp hole and 2 on the bottom of the bumper with a 3rd hole to adjust the beam angle with an 8mm nut runner. ![]() you can just see the lower fitting bolts in this picture:
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| | evol1 | Punto | 4 | 25-04-2006 10:18 |
| | Sonic74205 | Bravo / Brava | 25 | 26-03-2006 18:39 |
| | beau | Punto | 7 | 20-03-2006 18:55 |
| | uno_man | Uno | 2 | 29-11-2002 01:53 |
