Lamps by Post - For all your lighting needs
Comment
Guide Tools
Replacing the bulbs in the heater controls
johnlad27
23-02-2012
This is a fairly easy task to complete, just be carefully of the sharp metals behind dashboard.<br />
<br />
Tools needed:<br />
<br />
Various Screwdrivers, Flats, posi's and Torx bits.<br />
Ratchet bar<br />
Pliers<br />
The bulbs are here ...
Old 09-04-2015   #15
Re: Replacing the bulbs in the heater controls
Thanks for this!! Replaced my two yesterday as was running on 1 bulb for a few weeks before it finally gave up!
GeorgeFiatGP is offline Reply With Quote Quote
Old 12-04-2015   #16
GUTTED! I was up until midnight last night doing this on my daughter's car - I wish I'd seen this how-to!
Just to add, on her car, the wires to each off the bulb holders were tucked behind a plastic tab on the back of the heater control box, so if you just feel for them and pull on them, you might not get the bulb holder out (or damage the wires). you need to untuck them and then pull. (Although by then, I'd taken the control out so I could see them)!
Avocet is offline Reply With Quote Quote
Old 09-11-2015   #17
Poland
Unfortunately LED replacement bulbs won't work, they'll be just blinking (even with ignition off). At least one bulb must be real (or a resistor).
TzOk is offline Reply With Quote Quote
Old 27-12-2016   #18
PuntoR60SX has donated!
Thought these images of the back of the Grande Punto heater unit reflected in a small shaving mirror might be of interest as they show the wires you need to pull to extract the bulbs in their holders. Also visible is one of the small plastic tabs mentioned in Avocet's post above (16) that holds the wires in place.
One last thing I would add: if replacing the left-hand bulb turn the temperature control to cold to move the mechanism out of the way.
PuntoR60SX is offline Reply With Quote Quote
Old 27-12-2016   #19
varesecrazy has donated!
Quote Originally Posted by EvoSnowy View Post
Does anyone know how to do this on a Punto evo. The dash is built differently to the Grande shown
there is now a GUIDE for this and the 2012's,
see the joined EVO / 2102 FAQ's
Old 12-05-2017   #20
Hey!
Thank you so much for this post! I managed to fix one of my bulbs, (replaced both as it saves going in again) with ease. Brilliant post, shame I snapped pretty much all my clips..
Current 2007 GP 1.2 Active Owner (My First Car!)
MattPro is offline Reply With Quote Quote
Comment
Guide Tools
replacing stereo for Fiat Ulysse with steering wheel controls chimpo I.C.E 0 01-05-2010 21:01
(T) Heater controls bayley84 Punto (Mk2/2b) 6 01-02-2009 18:38
(T) heater controls not working g4ree Punto (Mk2/2b) 3 15-09-2008 00:04
(G) Heater Controls Gary196721 Scudo 3 16-12-2007 23:39
(G) Heater controls Howard Cinquecento / Seicento 5 05-09-2005 21:17
