FIAT Auto Specialist Team
Comment
Guide Tools
<!-- google_ad_section_start -->Heater Fan/Motor leaf and debris removal<!-- google_ad_section_end -->
Published by GotGrande
16-12-2011
Difficulty Level: 2
User Rated:
Difficulty Level: 2
First things first, locate the position of the heater fan and surrounding ducting.
The heater fan/blower and air flow ducting are directly under the glove box on the passenger side as shown (no need to remove glove box)
Name:	guide image.jpg
once you have located it, The First thing that you will need to remove the air flow ducting or black tube. this is held on with only one torx 20 screw
Name:	torx 20 screw location .jpg
Once Screw has been removed, slide out ducting from housing and put to one side as shown bellow.
Now you are ready to remove the Heater fan/motor itself. As you look up the the space were you just remove ducting there should be 3x 5.5 hex head screws showing. (circled below)
Name:	3 x 5.5 screw location.jpg
remove each once by one until heater fan is free (should just drop out)
Once the Heater fan/motor is removed clear on any leafs or debris trapped inside the fins. (in my case carpet??)
Name:	guide image4.jpg
Now all that is left to do it reinstall. (exact reverse of removal)
First push heater fan/motor back into place (get a friend to help to get fiat screw in, as can be tricky due to cramped space)
once all the 5.5 hex head screws are back in place find the black plastic Ducting and place back into position and srew back on with torx 20 screw
JOB DONE!! and many more warm and quite journeys
Hope this is of help to some people and is easy to follow.
I tried made it as simple as I could
Thanks NineHundred, RowingLad87, REJOINED, SJB1985, ozzy6271 and 3 others thanked for this post
Old 16-12-2011   #1
Re: leaf and debris removal
never knew it was so easy, nice one
GymJunkie is offline Reply With Quote Quote
Old 16-12-2011   #2
Or me haha, surprised no one had done a guide for this before now
GotGrande is offline Reply With Quote Quote
Old 18-12-2011   #3
Avid Shoe Wearer
ysidfa's Avatar
ysidfa has donated!
Just done it
Sounds SO much better
ysidfa is offline Reply With Quote Quote
Old 21-12-2011   #4
Serbia
Thank you Now the heating is much better and the noise is much lower
maliomladinac is offline Reply With Quote Quote
Old 23-12-2011   #5
Can someone post a picture of the tool required just so i know i'm buying the right one?
Puntoboyy is offline Reply With Quote Quote
Old 24-12-2011   #6
Avid Shoe Wearer
ysidfa's Avatar
ysidfa has donated!
Its a 5.5mm socket either on a ratched handle or an allen key, then a Torx 20.
Buy this if you need it.
http://www.ebay.co.uk/itm/Brand-New-...ht_2315wt_1039
Tom
Old 05-02-2012   #7
excellent. pretty much exactly trhe same as the old MK1 Puntos!
i will do this when this snow clears!
thanks again
1.2 8V '56 Grande Punto.
danielzieba is offline Reply With Quote Quote
Old 23-02-2012   #8
well my heater fan is rubbish and makes a right noise! and i took this out the other day before i found this guide and there was not one leaf/feather/blockage at all in the fan area. everything was above board. and i even turned the fan on whilst it was lose and spun great. but once it was all put back and screwed up. it was back to its normal rumbling slow self!
speed setting 1 is just pointless.
speed 2 still pretty pointless
3 is what number 1 should be like!
and 4 is kind of decent but still not amazing. get a slight breeze but nothing special.
whaattt the feeeeeck is going on!?
RAW90 is offline Reply With Quote Quote
Old 24-03-2012   #9
Australia
Re: Heater Fan/Motor leaf and debris removal
Quote Originally Posted by GotGrande View Post
Attachment 97292
Attachment 97293
Attachment 97294
Attachment 97295
Attachment 97296
Thanks for the help & instructions. LenV
LenV is offline Reply With Quote Quote
Old 24-03-2012   #10
Avid Shoe Wearer
ysidfa's Avatar
ysidfa has donated!
Quote Originally Posted by RAW90 View Post
Sounds like youve got an obstruction going on somewhere, use a MEGASRINK 2000 shrink ray and make your self 2cm tall and go on an adventure?
Likes RossBatten, RAW90 liked this post
Old 24-03-2012   #11
Cool Re: leaf and debris removal
the sun is shining and i had some spare time so after reading this guide i went out and done my fan motor, not much inside only a couple of small leaves but once i started my car up and had the fans going i noticed the horrid rumbling had gone! RESULT!
Thanks for the guide, very easy to understand.
ozzy6271 is offline Reply With Quote Quote
Old 03-04-2012   #12
Wenglish :)
Juggers2k's Avatar
Juggers2k has donated!
Are things still in the same place on models with dual-zone climate control?
Juggers2k is offline Reply With Quote Quote
Old 30-04-2012   #13
I cannot believe I have suffered a noisy fan for over a year. Top guide, I followed this guide and cleared out the debris from the fan and now its as quite as when it came out the factory. It literally took less than 10 minutes to do.
Fantastic.
Thanks eliott thanked for this post
Cinqster355 is offline Reply With Quote Quote
Old 02-05-2012   #14
Moderator
dombooth is part of the official FF Events Team :)
dombooth has donated!
dombooth is an honorary friend of the forum :)
DiffSpotter 3 - Rooms Champion
I will get round to doing this at some point.
Dom
Current Car: FIAT Bravo 150T Sport
And the mighty Fiat 126!
dombooth is offline Reply With Quote Quote
Comment
Guide Tools
(T) Leaf Springs cht Ducato 3 20-10-2011 21:34
(G) leaf springs mrf94 Panda (Classic) 12 04-11-2005 22:22
(G) re Leaf Springs mrf94 Panda (Classic) 7 07-09-2005 18:32
(G) leaf springs mrf94 Panda (Classic) 12 15-08-2005 19:01
(G) Leaf springs Harllequin Panda (Classic) 4 01-01-2005 01:41
