FIAT Auto Specialist Team
Comment
Guide Tools
Front disc change
Andy Monty
28-02-2011
<font color="red">This is intended as a guide only if your in any doubt over you ability to do this consult a qualified mechanic as your brakes are rather important</font><br />
<br />
<br />
bit of an add on to this guide as im not going over the intimate details of pad removal again for the
Old 05-10-2013   #15
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Front disc change
You got an s2 gp or a EVO? They are e-torx
Old 28-06-2014   #16
it seems that perhaps the caliper fixing bolts have torx heads. Anyone know what size please ,as don't really want to buy a whole tool kit when I ciuld just get a socket
DavyP is offline Reply With Quote Quote
Old 28-06-2014   #17
Not very good at using this site. As just found your reply to mylast year's query. The car is just a 90hp diesel dualogic eleganza
hp
Old 28-12-2015   #18
AB2011 has donated!
As an old codger taught in the days when torque was measured in lbs/feet, does the torque setting you give of 9.9/11.0(daNm) translate to 9 Newton Metres?
AB2011 is offline Reply With Quote Quote
Old 23-05-2016   #19
Hey, kinda unrelated but I managed to snap the alignment bolts that hold the discs in alignment (don't ask how, it's dumb). With a bit of difficulty I managed to align both the discs and wheels and put the wheels on. Does anyone know if the alignment bolts serve any strength purpose of just for the purpose of alignment. I've been driving my car a while and my brakes are all working fine since the wheel bolts hold on the discs and the wheels. Anyone know if this is still safe?
Brad Cogan is offline Reply With Quote Quote
Old 23-05-2016   #20
It seems to me like the bolts are only for alignment to make the wheels easier to put on. The wheel bolts also hold them in alignment and as far as I can tell provide the strength to hold everything together. Correct me if I'm wrong.
Old 14-07-2016   #21
Talking Re: Front disc change
19mm caliper across flat carrier bolts Torque 9.9 11.0 (daNm)
13mm across flats caliper bolts torque to 2.7 3.3 (daNm)
T30 torx bolts torque 0.9 1.4 (daNm)
Great guide. Can anyone try to explain to me how you work out the torque settings. rather new to al this and i was under the impression it was simply someone told you the amount so e.g 120Nm for locking wheel nuts. But this 9.9 11.0??? completely lost
So to sum up how do i work out the actual specific Nm to set my torque wrench too.
thanks alot guys
everson38 is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.6 Sx Front Disc And Pads Change donnabravo2k8 Bravo / Brava 2 22-09-2008 09:26
(T) Front disc and pads change Rustymini Doblo 0 16-09-2008 18:38
(T) front disc change Dougiebob Multipla 6 07-09-2008 21:43
(T) Disc change 48POP Cinquecento / Seicento 12 21-12-2005 18:13
