Comment
Guide Tools
<!-- google_ad_section_start -->Strut Top Bearing removal + Service / replacement  & Front Spring replacement<!-- google_ad_section_end -->
Published by Andy Monty
15-01-2011
Difficulty Level: 4
User Rated:
Difficulty Level: 3
First off this is a fairly complex task with the added hazard of having to remove the coil spring which is under a fair amount of tension so care should be taken.....
Tools needed
2 jacks (ideally if not some blocks of wood will do in place of one jack)
Axle stand and wheel chocks
Small 3 leg puller
Release oil
Grease
Socket set (18mm 17mm 16mm and 6mm hex alan socket)
18mm deep recess Ring spanner
Pozi 2 screw driver
flat screwdriver
hammer/ mallet
Decent spring compressors
set of spanners
Side cutters
Breaker bar/s
a selection of spanners (a 17mm is going to be needed for the drop links) a 10mm to suit the safety clamps on my compressors
So park the car in a safe place on level firm solid ground set the handbrake set the car in gear at some point before jacking loosen wheel nuts on the wheel your working on and open the bonnet.....
first job is to remove the wiper arms...
unpick the plastic nut covers with the flat screw driver
undo the 13mm nut
now a dirty windscreen is handy note where the wipers sit on the screen
fit puller and wind both arms off with the puller taking Great care not to hit the windscreen on the bottom edge or apply any pressure to it...
Now remove the 3 screws that hold the scuttle panel down followed by the rubber seal
Name:	Remove rubber.JPG
and remove the plastic scuttle trim taking note how it sits with the little bits of trim at each bottom corner of the windscreen ...
now you can get at the turret nut soak it well in release oil and leave to soak for a bit......
Name:	soak in pentireating oil.JPG
now take a 18mm ring spanner and a 6mm alan socket and wrench and loosen the nut off but do not remove completely just yet...
Name:	Strut top bolt.JPG
(If your having trouble removing it or you round the 6mm hex off the only option is going to be an air impact wrench to remove/ loosen which is what i did in the end as they were very tight)
Now chock the wheels and safely jack the car up and remove the wheel fully and axle stand the car.....
Name:	jack and stand.JPG
now remove the wheel......
as soon as your in spray the 1x top drop link bolt with penitrating oil along with the 2 hub to strut bolts and clean them up with a wire brush and soak again...
Name:	Arch lube and cables.JPG
whilst that does its job remove the cables from the strut clips ABS sensor (and pad wear indicator on the LHS wheel)
next remove the brake hose carefully having removed the metal clip ((which will probably snap)) i refitted mine and retained it in place with a cable tie which is what the fiat dealer did to mine when they did the other side under warranty
Name:	Brake hose off 2.JPG
Name:	Remove drop link.JPG
now remove the top drop link nut using a 17mm open ended spanner and a 16mm socket and pull clear to one side...
Name:	Spanner droplink detail.JPG
now loosen the 18 mm nuts off the 2 hub/strut bolts and remove the nuts..
Tap with a hammer to begin to remove them...
Name:	Undo 18mm headed strut to hub bolts.JPG
at this point chock up the wish bone so it can't drop and pull the drive shaft out i used another jack but you can use a pile of bricks or wood....
Name:	Hub support jack.JPG
now fully remove the 2 hub/ strut bolts...
at this point the strut should be swinging free in the arch a spare pair of hands can come in handy now to fully remove the top nut and guide the strut out of the arch taking care not to snag it on any cables or hit the body work
and your just about half way there now for a hazardous bit
before going any further read the instructions that came with your spring compressors keep any helpers at a safe distance and TAKE YOUR TIME its imperative that you compress the spring evenly and slowly be gentle and personally i would not use the cheaper spring compressors i have seen some been used where the threaded shaft have been bending badly were they to fail they could cause serious injury and possibly death should the spring suffer a sudden release of tension or the compressor fails.. If your not happy take your strut to a garage and smile sweetly and offer beer tokens for the next bit as most will have a hydraulic strut press which is much safer and faster than compressors
if not continue by fitting all three compressors evenly to the spring ensuring the safety retainers are tightened
that they are equally spaced
and are far enough apart to compress the spring
before tightening look how the spring sits in the cup at its stop
slowly tighten them a bit at a time until the spring feels loose between its bottom seat on the cup and the bearing on top
then remove the top nut the same as you removed the other using the ring spanner and 6mm alan key
Name:	top bearing nut.JPG
now remove the bearing assembly taking great care not to roughly handle or drop the compressed spring
this is the bit you have been trying to get at
At this point you can drop a new upper bearing assembly on and put it all back together
Or if you have noticed it starting to stick early there is a chance it is salvageable as long as the balls are not rusty and the race is in good condition you can take it apart and clean and re grease it just take care not to loose the ball bearings out of the race
first remove the top rubber
then split the race with a screw driver slowly working round it (do this over a tub as if all the grease has gone the balls will fall out and roll under any thing heavy and unmoveable in the garage
pull the metal bearing race open and degrease and clean the bearing area and the balls themselves
next use grease to stick the balls back in the carrier and put more over the top then reassemble
next refit the bearing onto the spring ensuring the spring sits over it and check the spring is seated in the stop at the bottom and replace top nut
release the spring compressors evenly and slowly then remove them checking the spring is sat right in the strut against the bottom strut
then put back in arch and through the hole in the turret top
and refit nut loosely to hold it in place
next refit bolts using the torque settings in this guide:
http://www.fiatforum.com/grande-punt...ront-back.html
then refit the cables hoses and wheel and road test as per the above guide
hope this helps
Thanks mattyo, AgnessGP, drof, idaho1, Thomas_Si and 1 others thanked for this post
Old 26-01-2011   #1
Re: Strut Top Bearing removal + Service / replacement
i have just noticed a clicking noise when low speed turning.
when the wheel is turned (static) the spring judders in its seats(cups)
if i hold the spring and twist i can move it (slightly)
poss snapped (just a tiny bit), or more likley a stuck top mount.
the car has just come back from service so i wonder with it being on beam ramp (while dropping oil) has it disturbed it at all
2007 grande punto
m-jet
devils fuel
stebell1@hotmail.com
ste is offline Reply With Quote Quote
Old 26-01-2011   #2
17.02 pm back from the garage ,new near side front top mount fitted genuine part.
48 done.
happy chap
2007 grande punto
m-jet
devils fuel
Old 26-01-2011   #3
Just done this myself following this guide.
The bearings were 17+vat each there abouts from the dealer and took 3 hours to do both sides of the car.
The only thing I can think I need doing as a result of this is get the tracking done, but so far have not noticed any problems with the steering pulling to either side at all.
Pedrolami is offline Reply With Quote Quote
Old 27-01-2011   #4
great guide
2007 grande punto
m-jet
devils fuel
Old 06-02-2011   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Pedrolami View Post
why, no need? Best to change the top bearings as you did as they are cheap.
Old 12-02-2011   #6
Thomas_Si has donated!
Your timing couldn't have been better with this Andy, my front passenger spring snapped on Friday
Got to go buy a puller and some compressors now.
The joys of motoring...
Fix It Again Thomas!!
1998 Fiat Punto 60 S 1.2L SPi
Now Driving
2006 Grande Punto Dynamic 1.2L 8V
Thomas_Si is offline Reply With Quote Quote
Old 13-02-2011   #7
Moderator
Andy Monty's Avatar
Andy Monty has donated!
not a problem if you have access to a air impact wrench and an impact 18mm socket (odd ball size) it makes the job so much easier
really tempted to invest in something like this then im not restricted by the length of my air line
im not sure if anywhere hires them out Argos might
if not the 18mm crooked ring spanner is a must have you wont get it with a socket or a normal spanner
http://www.teng.co.uk/631819-teng-to...er_1652_pd.asp
and this is the set of pullers i have
Massive gash
Just a little touch up
Old 20-02-2011   #8
Spring changed relatively easily.
If you're doing the passenger side you can get away without removing the wipers and scuttle.
I eased it up behind the bonnet stay and put my hand down behind it.
Slightly awkward but time saving
Now Driving
Old 31-03-2011   #9
i am on many forum sites and this has been the most helpful to date .
This guide was spot on ,managed it in about 1.5 hours Cheers
TED CRUD is offline Reply With Quote Quote
Old 01-01-2012   #10
Bulgaria
Useful guide Thanks
thegame is offline Reply With Quote Quote
Old 28-02-2012   #11
This is a TOP guide mate thanks, I was confused about the Torque settings so i asked a engineer at my work about the Deca formula DaNm
Deca is to the power of 10 so 10.5 = 105nm etc 5.4 = 54Nm
hope this helps
thanks again for a great guide
Lance
fiddler69uk is offline Reply With Quote Quote
Old 21-03-2012   #12
Great guide, Had a broken front spring and wouldn't have even attempted replacing it before. Took the time to grease up top bearing as well.
drof is offline Reply With Quote Quote
Old 30-04-2012   #13
Superb giude Andy, I printed this off and used it tonight to replace both of mine. The car is spot on again thanks to the 3 hours it took me following this guide. Nice and simple with this guide.
I am glad I read it all first as I had to buy the 18mm spanner you mentioned, that was essential.
Likes Andy Monty liked this post
Cinqster355 is offline Reply With Quote Quote
Old 02-05-2012   #14
GrahamL has donated!
Excellent guide, thanks.
Recently had both front springs snap within a few weeks of each other so this was very helpful in fitting the new springs/dampers.
Having seen how poor the original Fiat springs were I didn't want to fit the same ones again so ordered different springs and dampers as well as new top mounts etc. to make a complete new damper assembly for each side.
Took all the bits to local garage to have the springs fitted to the dampers and once they were fitted the guy there said he thought the angle the top mount was sitting on the damper didn't really look 100% right and therefore he wasn't sure if I might have the wrong springs. Of course without seeing the original ones (as they were still on the car) we couldn't be sure.
Anyways, I ended up ordering another make of springs just to be sure and after fitting they turned out to be identical to the first set, even though one was supposedly made by Sachs and the other by Killen.
So, for anyone else in the same situation, the top mounts are meant to sit at this strange angle and not straight as you'd expect:
When I finally removed the original Fiat dampers to fit the new ones the top mounts were exactly the same, also sitting at an angle.
Thanks Andy Monty thanked for this post
Likes 903, Andy Monty liked this post
GrahamL is offline Reply With Quote Quote
Comment
Guide Tools
(G) strut top bearing andysporting Grande Punto 1 22-12-2010 23:34
(G) top steering column bearing/bush levemircento Punto (Mk2/2b) 1 10-12-2009 20:06
(T) Strut Top Mount Replacement Guide Jamieboy Cinquecento / Seicento 12 05-07-2009 19:09
(T) Suspension Top Mount Bearing Rich Stilo 6 14-01-2006 17:53
