Lamps by Post - For all your lighting needs
Comment
Guide Tools
Fix for water in footwell/Rust at brake servo
GrahamL
02-07-2010
<div align="center"><b><u><font face="Times New Roman"><font size="5">FIAT Grande Punto</font></font></u></b></div> <br />
<br />
<div align="center"><b><u><font face="Times New Roman"><font size="5">Water leak, Rust at Brake Servo : Details + fix</font></font></u></b> </div> <br />
<br />
Old 13-06-2015   #15
Thumbs up Re: Fix for water in footwell/Rust at brake servo
Thanks Graham. The guide is excellent. I had exactly the same rust pattern as you. I my case, 3 of the clip/lugs on the hatch panel had broken allowing the water to run onto the bulkhead supprting the master cylinder. I drilled these out and used nuts and bolts instead. The seal looked ok, but I covered it in silcone to give it a fighting chance. I'll periodically douse the rusted area with waxoyl for as long as I keep the car.
john7 is offline Reply With Quote Quote
Old 13-06-2015   #16
Thanks Graham. I had the same rust problem caused by broken clips on the hatch panel. I will regularly treat it with waxoyl from now on.
Old 30-01-2016   #17
I have the same issue with my Fiat Punto.
Just to confirm, would normal Silicon work? The kind you get for bathrooms and tiling?
DonSalvati is offline Reply With Quote Quote
Old 23-05-2016   #18
I don't see why not as it's waterproof.
Michael Dranfield is offline Reply With Quote Quote
Comment
Guide Tools
(G) Help - Water in Footwell bilb27 Cinquecento / Seicento 3 30-06-2008 07:16
(G) water in footwell klemster Bravo / Brava 20 05-03-2008 20:00
(G) water in footwell bluesplayer Uno 18 07-09-2006 12:45
(G) Water in footwell Morty Mort Uno 6 20-07-2004 18:20
(T) water in footwell glynnoss Punto (Mk2/2b) 5 24-09-2003 01:49
