Comment
Guide Tools
Drivers door lock replacement / Repair
Andy Monty
31-05-2010
Well a regular complaint is the drivers door lock failing to open from the inside so here is how to replace and repair it <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
<br />
reasonably simple<br />
<br />
you will need<br />
<br />
a
Old 23-06-2014   #15
Re: Drivers door lock replacement / Repair
Andy, thanks for a very comprehensive guide, I am glad there are people like you in the world
RobMB is offline Reply With Quote Quote
Old 29-01-2015   #16
Brilliant Thanks that worked great followed the steps on a winter day snowing and raining on and off (the only day I had to do it in) took around 2hours including a cup of tea and the dremel work (keeping warm inside)
Worked great only side effect was the outside handle is not as good as it used to be have to give it a good yank but ill consider replacing the unit shortly.
mpfzx48k is offline Reply With Quote Quote
Old 28-09-2015   #17
Thanks so much for this. I sorted mine this weekend in about an hour start to finish!
CodeThief is offline Reply With Quote Quote
Old 24-10-2015   #18
Singapore
Hi All. Suffered the same common fate last night where suddenly, the driver's door cannot be open from within. Was relieved to realised that its a common issue from Fiat Forums.
Called local dealer and the price could be up to SGD200 for parts and labour. Went ahead to follow this guide and got it sorted. I didn't had the chance to buy any rubber washer and merely fixed the cover back as-is. Hopefully it will last!
I uploaded a video to let members here understand further on how the mechanism worked. Good luck and enjoy!
Terenc3Le3 is offline Reply With Quote Quote
Old 24-10-2015   #19
Singapore
Oh.. two more things by the way..
1) Those who had bought a new replacement instead of repairing the current; any identical issue thereafter? Because if its a design fault, I'm wondering if the new parts had this sorted out.
2) When fixing back at the step indicated by the 10th picture of the guide, I've put the white piece of plastic further back away (using black electronic tapes to thicken the rubber outer cable cover) so as to create more tension to the pull cable attached to the inner door handle. I believe you can explore this option if you experience unnecessary "play" in the door handle.
Just wondering if there are any other ways to shorten the middle metal cable to create more tension for pulling.
Old 09-06-2016   #20
Does anybody know where I can get the little black clip that holds the cable on to the back of the interior door handle. Somebody has broken mine and bodged a fix with cable ties but I'd rather have the proper clip.
My problem is that the drivers door doesn't turn on the interior light. I'm trying to figure out how to test at the connector before I get a new lock. Anybody know what colour wires got to the switch in the lock and how I can test?
Grande Punto 2006 3dr.
topbanana is offline Reply With Quote Quote
Old 23-10-2016   #21
Quote Originally Posted by steaders View Post
just chipping in, i had the exact same problem (wouldnt open from the inside only from outside) so i didnt bother taking anything off and compared the lock mechanism that i could see with the passenger side. i found that the problem was a metal lever n the drivers side which was connected to the inside handle had sprung above and on top of a plastic lever beneath it that it needed to push upwards when the handle is pulled. so just by using a screwdriver i rammed the metal lever back beneath the plastic lever (pulling on the outside handle made it easier to do this) and after a bit of effort i managed it! probably not helpful as its not tried and tested but just suggesting this to anyone reading this thread
Hi, I have exactly the same problem but I cannot see what I need to jam down. I tried something after which the door wouldn't open from the outside as well! I've now got it back to open from the outside but can't figure out which bit I need to push down. Any advice greatly appreciated as MOT is due in 5 days. Thanks
Arbysims is offline Reply With Quote Quote
Old 01-11-2016   #22
Older, but not wiser!
hotbulb has donated!
Thanks, guys! Mine played up today ... a bit awkward in Sainsbury's car park when you can't get out of the car, and then the door won't stay shut when you've finally opened it using the outside handle. I was able to fix it using Steader's trick. It's fine now, but I'll know what to look for in the future. :-)
hotbulb is offline Reply With Quote Quote
Comment
Guide Tools
(G) Fitting cables for door sliding door lock caledonian1 Doblo 0 17-11-2009 13:01
(G) Punto Door lock barrel replacement Kyled87 Punto (Mk2/2b) 6 11-05-2008 00:09
Bodywork/lock repair after break-in smurfhead Lets Talk FIAT 3 30-10-2004 00:09
(G) Door Replacement / Repair? bumcheeks Panda (Classic) 9 01-07-2004 07:29
