Comment
Guide Tools
<!-- google_ad_section_start -->1.2/1.4 MAP sensor replacement.<!-- google_ad_section_end -->
Struggling to start when cold, Poor fuel economy your MAP could be on the blink
Published by Andy Monty
20-02-2010
Difficulty Level: 2
User Rated:Unrated
The MAP sensor (Manifold Air Pressure) sensor Detects the amount of air in the inlet manifold (it also detects air temperature) and Adjusts the fuel mixture as required.....
If your car struggles to start (as in it fires up and the revs suddenly drop away it could be your MAP sensor is on its way out) You can't really clean it as it works on barometric pressure so will still work if its covered in oil...
so you have worked out that it is the MAP sensor causing you greif and have managed to source a replacement....
first check you have the Radio keycode (if needed) and take the negative terminal off the battery......
Open the bonnet and find your Map sensor
It (the MAP) lives on the upper drivers side at the back of the engine on the inlet manifold and is secured by one screw just below the Blue pipe between the bulkhead and the dipstick....
Attachment 74086
To replace all you need is a Torx (T25) screwdriver and perhaps a small slotted driver if the clip is stubborn.
Firstly you need to remove the wiring plug to do this pull the yellow tab upwards then pull the plug off the map sensor
now remove the fixing screw
then ease the Map sensor out of the manifold (its sealed in place by an O-ring) so just pull it and it will come out..
refit in the reverse in which you took it off
now ensure you have left the car an hour since you took the battery clamp off (this should wipe the ECU to enable the car to relearn what having a working Map sensor does for it)
now take the car for a long drive so it can relearn the engine management settings.
If the Engine management light stays on, Disconnect the battery and leave for an hour this should reset it
Old 24-03-2010   #1
Arrow Re: 1.2/1.4 MAP sensor replacement.
Where would i be able to buy a MAP sensor to replace it my self? any websites or any places in leeds i can get one from, postcodes if any one has them plz im rubbish at going to new places. best ideas for price wise too.
SIMON K
SimonKeebz is offline Reply With Quote Quote
Old 09-04-2010   #2
Trader Rating: 2
colin79666 has donated!
Quote Originally Posted by SimonKeebz View Post
Shop4Parts.co.uk stocks replacements.
colin79666 is offline Reply With Quote Quote
Old 09-03-2011   #3
When you go to the Shop4Parts.co.uk website the first thing is to select Fiat then the model, but there is no mention of the Grande Punto. Is it the same MAP Sensor used in the standard Punto?
JCW
1.4 Sport '06 July
jcwatrichmond is offline Reply With Quote Quote
Old 09-03-2011   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Massive gash
Just a little touch up
Old 01-06-2011   #5
bluepunto2 has donated!
nice simple guide, but when you mention a symptom as poor fuel economy, what about a 1.2 8v grande thats only doing 37mpg at its best?.
also when you set off from a junction for example. it will set off and then within a second it feels like it pulls back, loses power then its fine after that...
2007 "56" Grande Punto Dynamic 1.2
4653
bluepunto2 is offline Reply With Quote Quote
Old 13-06-2011   #6
When does it end..?
tjetface has donated!
Quote Originally Posted by bluepunto2 View Post
Got a 1.2 8v aswell, it's not your map thats on the blink the loss of power in first gear! Usually its when your accelerating pretty slow in which case you should slap it into 2nd gear before you get that point, it feels uncomfortable in 1st before it pulls back. If you slap your foot down in 1st you don't get the loss of power do you? Not that theres a great deal anyway, think my bike when i was 8 got to 60 faster.
tjetface is offline Reply With Quote Quote
Old 19-07-2011   #7
South Africa
Could this also cause the engine to turn but not start? Mine has al the symptoms that was described with the added benefit of not starting and cutting out some times. FIAT SA has plugged it onto the computer three times now and has not found one thing wrong. In addition I had to replace the fuel pump about a month before this happened, could this be related? I would love to hear your feedback as I would like to make FIAT pay if they caused the mess.
Garron is offline Reply With Quote Quote
Old 24-08-2011   #8
South Africa
Funny this, it was a Relay...
Old 20-11-2011   #9
Quote Originally Posted by Garron
Do tell! I'm having the same issues with my 1.8 Marea.
John Mc is offline Reply With Quote Quote
Old 01-04-2013   #10
I had the cold start problems and Check Engine warning. Thanks to this forum it lead to the MAP sensor. After using this guide to locate it I removed it and found it to be covered in mayo (oil/water mix). A quick clean with electrical cleaner and cotton buds and battery disconnected for an hour the problem has now gone and car starts first time!
Wes
07WES is offline Reply With Quote Quote
Old 19-04-2013   #11
Anyone know here this is on a 1.9? I don't remember ever noticing blue pipes
DueUno is offline Reply With Quote Quote
Old 26-09-2013   #12
I followed this guide as I had the same issue but after fitting the new map sensor everytime i stopped at a junction the car cut out. I ended up putting the old map sensor back which works ok apart from the starting issues. Any ideas?
vesper73 is offline Reply With Quote Quote
Old 07-10-2013   #13
Portugal
Quote Originally Posted by vesper73 View Post
did you notice anny inprovement on fuel economy or perfomance with the new one?
apart from the cut out problem ?
i m about to order a Aftermarket one
http://www.ebay.com/itm/171134004614...84.m1438.l2649
now kind of scary !
santa cruz is offline Reply With Quote Quote
Old 07-10-2013   #14
I didn't. Too busy stopping it from cutting out. Anyway I cleaned up the old one a refitted it and it ran much better. Have sold the car now so not sure if it's still ok or not.
Comment
Guide Tools
(G) MAP Sensor replacement/fitting costs BarchettaTK Stilo 15 05-11-2009 23:47
MAP Sensor replacement/fitting costs BarchettaTK Garages 0 03-11-2009 11:22
(T) HT leads, MAP sensor, Lamda sensor & dizzy cap ashar786 Uno 1 30-06-2008 01:37
(T) punto 1.3 multijet MAP sensor & IAT sensor spence Punto (Mk2/2b) 0 14-06-2008 09:25
(T) Oil on MAP Sensor & Sensor wires scorched?! DaveX Stilo 6 09-09-2006 08:17
