Comment
Guide Tools
1.2/1.4 MAP sensor replacement.
Struggling to start when cold, Poor fuel economy your MAP could be on the blink
Andy Monty
20-02-2010
The MAP sensor (Manifold Air Pressure) sensor Detects the amount of air in the inlet manifold (it also detects air temperature) and Adjusts the fuel mixture as required.....<br />
<br />
If your car struggles to start (as in it fires up and the revs suddenly drop away it could be your MAP sensor
Old 08-10-2013   #15
Portugal
Re: 1.2/1.4 MAP sensor replacement.
going to clean this thing first and lets see if improve
tanks
santa cruz is offline Reply With Quote Quote
Old 25-11-2013   #16
Having trouble starting my 07 1.2L Grande Punto Active in the recent cold weather. During the cold snap earlier on in the year, garage replaced the engine coolant sensor, which at the time seemed to fix the problem. However, with the start of the cold weather this week, I'm getting the same problem - difficult to start, and when it finally starts, the revs die, then engine shuts off.
So I'll have a wee nosy at the MAP sensor, and see if giving it a clean / cleaning the electrical contacts helps any...
BrianI is offline Reply With Quote Quote
Old 28-11-2013   #17
Quote Originally Posted by BrianI View Post
Got the MAP sensor out this morning for a clean. Apart from a slight smearing of mayo (oil/water mix) the sensor was pretty clean. Wiped the small amount of may off with a lint free cloth, and refitted it. It's a bit warmer today, so no issues starting the car either before or after cleaning the MAP sensor. Always seems to be difficulty starting when it's below freezing.
Anyways, I have a OBD reader on its way from the bay of e, so I'll see what fault codes have been flagged up before investigating this further.
Cheers!
Old 04-12-2013   #18
Got obd reader in the post the other day. Error code of p0115 flagged up. Coolant temperature showing 54C on idle after start up, while air intake temperature shows 108C. I know its a bit milder today, but not that warm!
Incidentally, car started first time.... I did have the coolant temp sensor replaced in april this year, so I'm leaning towards a faulty MAP sensor?
Old 03-01-2014   #19
Map sensor replaced, so far no issues with the car starting. MPG has dropped quite a bit though, probably due to the ecu relearning.
Old 20-01-2015   #20
is the same sensor used for diesel and petrol please
nigel273 is offline Reply With Quote Quote
Old 29-05-2016   #21
Pandaactiveman has donated!
Quote Originally Posted by bluepunto2 View Post
nice simple guide, but when you mention a symptom as poor fuel economy, what about a 1.2 8v grande thats only doing 37mpg at its best?.
also when you set off from a junction for example. it will set off and then within a second it feels like it pulls back, loses power then its fine after that...
Did you ever get to the bottom of this. I have a 2012 Panda 169 with the 1.2 engine and it behaves exactly the same....
Pandaactiveman is offline Reply With Quote Quote
Comment
Guide Tools
(G) MAP Sensor replacement/fitting costs BarchettaTK Stilo 15 05-11-2009 23:47
MAP Sensor replacement/fitting costs BarchettaTK Garages 0 03-11-2009 11:22
(T) HT leads, MAP sensor, Lamda sensor & dizzy cap ashar786 Uno 1 30-06-2008 01:37
(T) punto 1.3 multijet MAP sensor & IAT sensor spence Punto (Mk2/2b) 0 14-06-2008 09:25
(T) Oil on MAP Sensor & Sensor wires scorched?! DaveX Stilo 6 09-09-2006 08:17
