Closed Guide
Guide Tools
<!-- google_ad_section_start -->Oil change (1.2 8V)<!-- google_ad_section_end -->
Oil change (1.2 8V)
simple 30-40 min job to keep your engine well protected
Published by Andy Monty
26-09-2009
Difficulty Level: 3
User Rated:Unrated
Oil change (1.2 8V)
First things first Used Engine oil is a known Carcinogenic medium so do your best to avoid direct contact with your skin wear suitable gloves and wash skin well with hot water and soap when finished ..
Also its a known pollutant and a criminal offence to dispose of oil down the drain it must be disposed of safely and legally
For your nearest disposal point (for oil and filter) look here: http://www.oilbankline.org.uk/ Or call 08708 506 506
Equipment you need:
Jack/ axle stands/ or ramps
Funnel
Measuring jug
12mm alan key or 12mm Hex socket,
Filter removal tool or vice like grip
Hammer (if sump plug is stubborn)
Latex / Vinyl gloves
Rags / blue roll
Oil pan or large tray
Container for waste oil.
Fresh oil and suitable Oil Filter would also be a good idea too
Oil drains better if the car is warm so take it for a short run prior to draining.. ( I pre-soaked the drain plug with penetrating release oil 24 hours prior to removal)
First raise the front end of the car safely...
Next open bonnet and remove oil filler cap...
Now get under car (right hand side(( uk drivers side)) locate Sump drain plug at the lower right back side of the sump
Name:	Undo sump plug.JPG
Name:	12mm alan key.JPG
This takes a 12mm HEX (alan) Key to remove either a 12mm Alan key or a 12mm hex socket attached to a ratchet some might be tight so the alan key might need a tap with a hammer to crack any corrosion
Once loose slide you drip pan under the sump drain slightly more towards the back of the car as the oil will come out under a bit of pressure
Now remove the sump plug fully using the 12mm alan key ((anti clockwise))
((doesnt matter if the sump plug drops into the drip pan you can retrieve it later))
Now with the old oil draining away its time to remove the filter which is located on the Front of the engine between it and the radiator
(highlighted in Yellow)
Mine was removable by hand but you might need a oil filter remover ((it unscrews anti clockwise))...
Move your drip pan under the filter to catch the oil which is remaining in the filter
Try not to drop it into your oil pan
Now let the car drain for a while 30 mins later i still had a slight trickle so the longer the better It goes without saying DO NOT START THE CAR WITH NO OIL IN!
Once you are happy there is no more oil left to seep out retrieve and wipe clean the drain plug, oil filter area and sump with a rag
refit the sump plug snugly nipping up with the 12mm alan key.. (there is no sump plug washer or seal to replace its a tapered thread which seals itself when tight)
Next get your new oil filter... give the Rubber seal a wipe with some fresh oil and screw on hand tight..
Name:	Oil filter.JPG
Now youre ready to refill with oil..........
Name:	Oil and jug.JPG
The 1.2 8V takes 2.6 Litres of oil ((4.58 pints)) to bring it to way on the dipstick And as T14086 advises below 3.2 Litres to fill it to max
Pour in slowly and allow to settle and check its showing on the dipstick
Next get in the drivers seat and start the car ((DO NOT REV THE CAR)) you will notice the Oil pressure light stays on for about 5 seconds then should go out.
(this is due to the oil pressure sensor been deprived of oil whilst the oil pump fill and primes the oil filter)
Stop the car then check oil level again....
Now wipe any oil from the sump area and filter and leave for a while to check for leaks
Happy motoring.
Thanks TBoneMurphy, kyle96, Andi9386, nesma, ntrindade and 4 others thanked for this post
Likes TBoneMurphy, PointStreet2015, roy2869 liked this post
Old 26-09-2009   #1
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Oil change (1.2 8V)
I use 3.2L to bring oil to 'max' (that includes filter) but good one mentioning the following;
First things first Used Engine oil is a known Carcinogenic medium so do your best to avoid direct contact with your skin wear suitable gloves and wash skin well with hot soap and water when finished ..
Very sensible & good guide Andy, thanks once again
Thanks K-Bab00, Andy Monty thanked for this post
T14086 is offline
Old 04-11-2009   #2
Thumbs up Re: Oil change (1.2 8V)
Great guide, cheers for the help!
LUHG
K-Bab00 is offline
Old 04-11-2009   #3
Very useful for me ,thanks for sharing.
fordliu is offline
Old 02-12-2010   #4
Matt Boulton has donated!
hi
i have a 1.2 grande punto 2008
what sparkplugs, oil and oil filter do i need?
struggling to find part numbers
cheers
Matt
Matt Boulton is offline
Old 04-12-2010   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
5/40 fully synthetic (check you hand book fiat keep altering the exact spec
Fiat OEM oil filter 46544820
spark plugs 55190788
taken from eper
http://eper.fiatforum.com/eper/navi?...DRIVE=D&RMODE=
also look on ebay as a fiat dealer is doing full service kits for just shy of 40
http://cgi.ebay.co.uk/GENUINE-FIAT-P...#ht_558wt_1059
there is also http://www.shop4parts.co.uk/ who give 10% off to Donated forum members
Thanks Matt Boulton, johans fiat thanked for this post
Massive gash
Just a little touch up
Andy Monty is offline
Old 08-07-2011   #6
Netherlands
DO NO, I REPEAT - DO NOT TROW 3.2LITER (3.2L) OIL INTO YOUR 1.2L 8V GRANDE PUNTO, ITS TOO MUCH
ACCORDING TO THE MANUAL, 2.6L IS ENOUGH TO FILL THE ENGINE, INCLUDING THE FILTER.
BELIEVE ME, ITS A B*** TO GET TOO MUCH OIL OUT OF IT...
IVE SENT A PM TO THE MODERATOR
mikee123 is offline
Old 09-07-2011   #7
Moderator
Andy Monty's Avatar
Did you run the car for a couple of minutes after Putting in 3.2l or not?
and who did you PM i haven't got anything?
Massive gash
Old 09-07-2011   #8
Netherlands
I pmmed moderator: T14086
About running the engine, after filling it up > Yes i did.
Once again, per instructions of the manual (FROM FIAT)
2.6Liter is enough to fill the ENGINE + FILTER, T14086 probably has a Multijet 1.3 but didnt tell us that.
Otherwise, you end up with a soap-pump, attached to a hose like me(or get an oil pan, if you have so - get it all out again, same mess , and measure it off again, etc) to get 0.5L out of it again
PLEASE, edit / change the guide, its providing the wrong information.
mikee123 is offline
Old 09-07-2011   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
This is NOT an official Fiat forum, all information is 3rd party and wether you want to take that advice is your choice, this forum is NOT responsible. If you ant to put 2.6 in then good for you, I put in 3.2.
Personally I don't care what the manual says again it's up to the individual to take or disregard the advice.
T14086 is offline
Old 09-07-2011   #10
Netherlands
'Personally I don't care what the manual says'
right..
and
'If you want to put 2.6 in then good for you, I put in 3.2.'
right...
Doesn't make much sense to me, but could please confirm ur driving a 1.2Liter 8valve grande punto? ; )
mikee123 is offline
Old 10-07-2011   #11
Netherlands
Duwd, just admit you provided the wrong information for a 1.2L 8v.
Here in this posting, you're telling about your 'miles per gallon' with your 1.3Multijet, you dont have a 1.2, and i was nearly screwed by you not reading the topic title:
http://www.fiatforum.com/idea/200434...ml#post2149069
Thanks buddy, and with such an attitude, i think ur a pretty bad moderator as well!
mikee123 is offline
Old 10-07-2011   #12
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
Wow, you really have no idea who are you talking to, do you!
Also, what does it matter what he is driving Surely you are allowed to give advice based on other cars that you may, or may not have, worked on/driven.
Stu DemonD is offline
Old 10-07-2011   #13
OK it's only easy when you know the answer & all that, but changing the oil & filter on a car is not exactly rocket science
Personally, & this is not directed at anyone in particular, if you need a guide to change the oil & filter, it would be best to leave it to some one else. Even with limited skills this is one of the easiest jobs you can do on a car.
Consulting a manual perhaps to locate a hidden filter........The dipstick comes in handy as well.
jimboy is offline
Old 10-07-2011   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by mikee123 View Post
OMG for the last 8 years I thought I had a 1.2 petrol when it actually was a 1.3 diesel...how stupid of me
T14086 is offline
Closed Guide
Guide Tools
(G) Oil Change skinnyvinny Cinquecento / Seicento 3 30-08-2012 22:49
(T) No oil pressure after an oil change. rawill Uno 7 03-08-2009 09:37
(T) Help with an oil change please cbrooks Multipla 8 02-01-2009 11:48
(T) Doing oil change, how much Oil needed? beany_bot Grande Punto 11 04-12-2008 14:34
(G) Oil change panda04 Panda 4 22-06-2007 09:51
