How to De-Wiper the Rear.
What you will need:
8mm socket (1/2 inch)
Drill and 6mm drill bit
Philips screw driver
23mm gromit (or modified 24mm)
Light oil (WD40)
Washing up liquid (optional)
15 Minutes
1. Remove the bolt under the cover of the wiper with a 8mm socket and wiggle the wiper untill it comes off, If its stuck WD40 should help.
2. Open boot and remove the screw that holds the boot lid inner cover on and pop off all the way round, remove cover.
3. Drill out the 3 rivets that hold the motor in place with a 6mm drill bit and unclip the electrical connector, then remove the motor.
For safe keeping remove the gromet from the window and put back on the motor spindle then put bolt back on.
4. Secure away the electrical clip tighty to avoid rattles.
5. Clean the window area and fit the gromit, 23mm is best fit but 24mm are more readly available so you can just modify these a fraction if you wish. Halfords sell gromits 19mm, 22mm, 24mm, & 25mm for £1.59. You can put washing up liquid round the gromit to aid fitting.
6. Clip the inner boot cover in and screw on. Clean window and boot area and away you go....
Hope this helps anyone wanting to do this mod, Very easy.
Ste..(y)
