FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Replacing the Headlight, side light and indicator bulbs...<!-- google_ad_section_end -->
quick and easy when you know how.....
Published by Andy Monty
15-12-2008
Difficulty Level: 2
User Rated:
Difficulty Level: 2
Bulbs......
As standard the Grande punto uses......
A H4 Halogen 55/60W bulb for Headlight and Main beam (ensure they are UV cut)
A 501 5w wedge (capless) bulb (clear) for parking/side lights
A 581 21W amber bulb with 120 degree offset pins for the indicator
Thanks RowingLad87, cjdl, jjr0305, willp27, lukemortlock7 and 16 others thanked for this post
Likes cjdl, EvoStevo, wezza2010, Juppy93, Andi9386 and 3 others liked this post
Contents
<< <    Next Page: Replacing the headlamp bulb.... (Page 1 of 4)    >  >>
Old 15-12-2008   #1
Vimto Rolf has donated!
Re: Replacing the Headlight, side light and indicator bulbs...
what indicator bulbs have you got there?
they look blue as well
Vimto Rolf is offline Reply With Quote Quote
Old 15-12-2008   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Quote Originally Posted by Carl "Rolf" Dawson View Post
http://www.care4car.com/productdispl...tor_Bulbs.html
Thanks Vimto Rolf thanked for this post
Massive gash
Just a little touch up
Old 05-05-2009   #3
Replacing my side lights with blue LED's. Only one will turn on at a time with a standard bulb in the other side. if i have them both in they just flash.
Any one help me out, its driving me mad
K1MB3R is offline Reply With Quote Quote
Old 05-05-2009   #4
Moderator
Andy Monty's Avatar
Quote Originally Posted by K1MB3R View Post
the GP doesn't like LED's as it upsets the resistance in the circuit
http://www.fiatforum.com/grande-punt...warning-2.html
http://www.fiatforum.com/grande-punt...idelights.html
Massive gash
Old 05-05-2009   #5
Dame GP.. The only fault with it so far lol
Hmm Gunna get some MTEC bulbs and mayb put the LED's for the number plate.
Cheers for the know how
Old 12-07-2009   #6
Lee.Johnston has donated!
Do you know what type of bulb the side repeater is?
Grande Punto Active Sport 1.4 Crossover Black
Lee.Johnston is offline Reply With Quote Quote
Old 27-07-2009   #7
Moderator
Andy Monty's Avatar
Quote Originally Posted by Lee.Johnston View Post
501 amber
Massive gash
Old 29-07-2009   #8
KIM1B3R this may help, you need a load resistor for the LED side lights. the problem is the LED does not draw enough power for the body computer to recognise as a full "load", therefore it turns off that circuit until a "load" is present, so your LED doesn't light up. The Load Resistor fixes this problem by drawing power and tricking the body computer into reading a load in the circuit and therefore keeping the circuit turned on.
rob56dzo is offline Reply With Quote Quote
Old 12-08-2009   #9
Trader Rating: 2
colin79666 has donated!
Ta for the guide
Replaced my headlight and sidelight bulbs today
Got xenon headlight bulbs and went back for blue coated sidelight bulbs when I saw how yellow they looked when the headlights were one.
Fiat really need to improve the detailing in their manual as it tells you nothing compared to a walk through like this
colin79666 is online now Reply With Quote Quote
Old 13-08-2009   #10
Bulgaria
Hi guys,
I bring up this old topic because I have the same problem.
What i really want to know is, are the lights connected together, in pairs?
I have a Fiat Stilo. I tried searching for a 5W load resistor, couldn't find any. In this case we should have one load resistor connected to one bulb terminal on each side? I have 4 bulbs, if they are connected 2 by 2, then 2 resistors, every bulb for itself - 4 resistors but 5W?!
GTipo is offline Reply With Quote Quote
Old 16-08-2009   #11
Moderator
Andy Monty's Avatar
Quote Originally Posted by GTipo View Post
Hi guys,
yes
http://www.fiatforum.com/grande-punt...ml#post1773753
Massive gash
Old 03-09-2009   #12
It says on this guide A H4 Halogen 55/60W bulb for Headlight and Main beam but when I went to change a headlight bulb in my car I found it was a H1 bulb
aphilpot is offline Reply With Quote Quote
Old 05-09-2009   #13
Trader Rating: 2
Quote Originally Posted by aphilpot View Post
oem lights have H4 bulbs, is your car modified?
H4 works for both hi and dipped beam, other don't so its important you get it right. Besides they are different physical sizes so they should fit if they are wrong.
Old 07-09-2009   #14
Moderator
Andy Monty's Avatar
Quote Originally Posted by 30111987 View Post
only H1 bulb in the GP is in the front foglight...
Massive gash
Comment
Search this Guide:
(T) Side light and indicator bulbs? Ned Flanders Stilo 4 07-02-2008 08:56
(G) drivers side headlight bulbs J J Stilo 12 27-01-2007 13:02
(T) Replacing Headlight Bulbs - How To? harrison1980 Bravo / Brava 11 20-04-2006 05:56
