Mr. FIAT
Comment
Guide Tools
<!-- google_ad_section_start -->Front Bumper Removal<!-- google_ad_section_end -->
Published by Aircooledbug
10-12-2008
Unrated
User Rated:
Difficulty Level: 2
Here is a guide on how to remove the front bumper on the Grande Punto.
First thing is to is remove the grilles top and bottom. Jack the car up and put on axle stands (makes the job alot easier!) if not do one side at a time. Undo the screws, working from the bottom, up. (If you have fog lights dont undo the screws under the light and the one at the top) Then do the screws underneath (pointed out by my picture) then you have two screws that hold the bumper to the arch. One is easy to get to the other is a pain, and this is where the axle stands come in handy. Because the car is rasied, I slid my hand up the back of the bumper to undo the screw inside the bumper. Then when tall these are done (18 in total) then undo the top four under the bonnet making it 22 in total. ( I used old carpet to rest the bumper onto to save from being marked.)
Then obviously do the reverse for puting back on.
If you have problems with anything dont hesitate to PM me
Ps, the picture shows lines to the screws, the screws are located in the same place on each side of the bumper.
Thanks RaffatheRed, kyle96 thanked for this post
Likes RaffatheRed liked this post
Old 10-12-2008   #1
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Front Bumper Removal
"Then do the screws underneath (pointed out by my picture)"
where
Old 11-12-2008   #2
Dub Dub Dub
Aircooledbug's Avatar
Aircooledbug has donated!
lmao, it wont show up for some reason, nor the head light on the other guide!
But here it is anyway
2006 Caribbean Orange 1.9 Multijet 130
Aircooledbug is offline Reply With Quote Quote
Old 14-11-2010   #3
Slovenia
What type are these screws, any Torx or are they all the usual nuts? If they are Torx, what size are they?
Primoz is offline Reply With Quote Quote
Old 14-11-2010   #4
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Quote Originally Posted by Aircooledbug View Post
because you attached the image but didnt insert it
so after attaching all the images or image
click the
this gives you a drop down of the attached image
you can click on image to attach or insert them all
it allows you to add images at specific points of the guide
Old 14-11-2010   #5
Slovenia
Would it be possible to get better pictures of the screws needed to be removed?
The top 4 are obvious, but where are the 5 (10) under the bumper? 3 of them i think are visible, if one of the 3 is in the hole and is very stick like (no head). Are the middle 2/4 behind the skirt?
Also where are the 5 by the fender, especially the one 'under the bonnet'? I found 2 phillips heads and a Torx (on the joint between the bumper and fender) in the wheel well.
And i suppose this would actually be miles easier to do if the car was lifted up
Old 10-02-2014   #6
Sorry to dig up an old thread, but ......
The two screws that attach the front bumper to the arch, do you have part numbers for them?
Looking at EPER i don't know if its this first set of screws or the second set with a fitting?
Also is the outer screw the same as the inner screw? It appears the garage decided not to put all my screws back in from the looks of things.
KBonnie is offline Reply With Quote Quote
Old 25-07-2015   #7
Hi , just tried to get the front bumper off but the phillips screws the the wheel arches just wont budge as they are all rusted up.
RaffatheRed is offline Reply With Quote Quote
Comment
Guide Tools
(G) Front Bumper Removal katanabandit1 Stilo 20 23-08-2008 18:21
(T) Front Bumper Removal / Bodykit peterjames13 Multipla 3 26-07-2006 12:24
(T) Seicento front bumper removal - quick help please! paulbfd Cinquecento / Seicento 5 16-07-2006 16:55
(T) front bumper removal keith price Stilo 3 25-02-2006 20:56
(G) mk1 front bumper removal Ervin Punto (Mk1) 2 27-04-2005 22:36
