Comment
Guide Tools
How to Install / replace the Pollen/Cabin filter
Step by step guide to Replacing or fitting a new pollen filter
Andy Monty
04-06-2008
No really tools are needed apart from a small paintbrush and a Hoover with a crevice tool..<br />
<br />
The Replacement Interval of the filter varies obviously with the environment the car is used then again a quick hover regularly can eek a bit more life out of the filter as OEM replacement is
Old 25-07-2014   #45
Re: How to Install / replace the Pollen/Cabin filter
Excellent guide - thank you
having just done mine - I found there was a screw in the bottom of the filter housing. Also when I removed the filter it had the airflow arrow facing towards the engine - contrary to the advice in this guide. I have had the car from new and the only time the filter has been changed is now - so the factory must have fitted it wrong.
Anyway thank again as the filter was badly clogged after just 2 years and 10k miles.
116d Sport
82 323i
90 320i
2012 Punto Easy
89 240DL est
hennabm is offline Reply With Quote Quote
Old 09-10-2015   #46
Singapore
I've tried to replace it myself with success. However, I'm not entirely sure if the filter is sitted into the chamber properly i.e. no folds/tears/crumpled. Because it was pretty hard to get it in.
Terenc3Le3 is offline Reply With Quote Quote
Old 24-10-2015   #47
Singapore
Hi. Have you all tried taking the filter out to check if it sitted correctly? Mine doesn't seem to sit "flatly" as per picture below. Worried that this means gaps of unfiltered area which sort of defeats the purpose of having this filter.
Old 13-01-2016   #48
Once I'd figured out it was on the inner side of the passenger footwell(took longer than it should have), I eventually got mine out in a similar state. Not quite as bad though.
After spending 10 minutes on my back doing automotive yoga trying to get the new one back in, I care not a fig if gaps are left. I'm just glad it EVENTUALLY managed to slip in, bent or not.
I also broke the clip putting the cover back on
Ta for the guide! Onto that other air filter now....
1.4 16volts Crossover Black
joey_jo_jo_jnr_shabadoo is offline Reply With Quote Quote
Old 08-07-2016   #49
As it was 2 years ago that I last did mine, thank goodness for this guide to refresh my mind on how it is done.
Thanks again
116d Sport
82 323i
90 320i
2012 Punto Easy
89 240DL est
Comment
Guide Tools
(T) Cabin Filter lola's dad Multipla 1 27-10-2007 20:16
(T) Cabin filter ts86net Marea 13 01-03-2007 14:25
(T) Pollen filter=cabin filter? waynem325 Stilo 5 17-10-2006 18:28
(T) Cabin Filter 1.8ELX hatters1999 Bravo / Brava 10 25-05-2004 03:42
(T) Cabin filter M@XI Stilo 2 21-04-2004 00:19
