The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Fitting Reverse Parking Sensors<!-- google_ad_section_end -->
4 sensor with LED display type
Published by tommy_8884
09-04-2008
Cool Prep and bumper removal
Hello all.
After getting a lot of help on this forum on how to fit parking sensor (my original post), i decided to write a guide after doing mine. Unfortunatly my digital camera packed up so i had to use my iphone camera which is not very good at all. So i appologise for the quality of the photos
This guide shows how to fit an 4 sensor with LED display type of kit. I picked one up from ebay for £25 with postage. The kit was of the sort shown here
Step 1 Prep:
For this job you will need
  • A parking sensor kit (obviously)
  • a wireless electric drill
  • a screwdriver
  • stardrive bit
  • phillips bit
  • wire strippers
  • stanley knife
  • hole saw bit (usually provided with kit)
  • Jack ( axel stands would be useful)
  • wheel brace
  • 1-3 hours of time
Step 2. Removing the bumper:
I was told you dont have to do this, but for the best access and to use the marks fiat provide, i advise it.
Firstly remove the carpet in the boot. Then remove the plastic cover just above the bumper inside the boot. There is 1 stardrive torque screw on the top and 2 phillips screw inside the boot. Once out, dont be shy, give it a big tug and all the clips should come free:
Now remove the 2 top screws under the boot lid, shown below. These are stardrive torque screws.
Next remove the 4 screws at the bottom of the bumper on the underside of the car. 2 are stardrive torque screws and 2 are phillips:
Next step is to remove the 4 screws in each wheel arch. I was told this could be done without removing the wheels but i couldnt get to them, maybe you can ( if you dont have 17"s then give it a go with it jacked up before removing the wheels) but here goes. Jack up the car:
Then get that wheel off and remove the 4 screws. Start from the bottom and work your way up. The bottom 3 are phillips at the top one is a stardrive torque screw.For the top one you will have to bend the plastic a bit to get to it, its well hidden up there. (When putting this back later put the top screw back first) Also you may find it difficult on a few of these screw as mine were solid with mud!
If you have axel stands get them under now and remove the other wheel and do that side. I didnt have axel stands so i had to put the wheel back on to do the otherside. What a ball ache!
Once you have removed all 14 screws (count them and don't lose them, try to remember where they go) persuade the bumper off, it should come easily BUT be careful, make sure you put towels down to rest it on so you dont hurt your paint and you will have wires to remove before you can put it down. 2 people are good here but i managed it on my own. Once free you will see 2 number plate lights that just twist out, as well as the reverse light on the left and fog on the right (if in UK). All of them twist out.
Now put it down carefully on somethjing soft (i used the boot carpet)
The bumper is off so go to the next page!
Contents
Article Tools
<< <    Next Page: Fitting the sensors (Page 1 of 2)    >  >>
The following 2 users say "Thank You!" to tommy_8884 for this useful post:
Alex_gregory_uk (04-07-2008), snownrock (20-04-2008)
Old 09-04-2008
Tom - 1.9 GP Sporting
venomco's Avatar
Trader Rating: (0)
venomco has donated! United Kingdom
Re: Fitting Reverse Parking Sensors
Yay you used a towel / blanket
Good guide btw
1st FRONT VINYLED GP, SIDE STRIPES, TINTED WINDOWS, ABARTH BADGES, RED INTERIOR STITCHING, ABARTH HEAD RESTS, ABARTH CARPETS, FULL VIBE SOUND SYSTEM, 12" VIBE SUB, 800w VIBE AMP, 1200w VIBE AMP, VIBE FRONT AND REAR SPEAKERS, 177BHP, LED DAY RUNNING LIGHTS, RED CALIPERS, DRIVING CAMERA, REVERSE SENSORS, BLACK ALLOYS M-Jet Alloys for sale
venomco is offline
Old 09-04-2008
Multijet 130
tommy_8884's Avatar
Trader Rating: (0)
tommy_8884 has donated! United Kingdom
Good guide btw
Thanks. Could not have done it without yours and others advice!
The guide took longer than the job!
57 Plate GPS Multijet 130, Black
Red Painted Calipers, Footwell LEDs, Reverse Parking Sensors, Vibe Front Components, 12" Active Vibe Sub
tommy_8884 is offline
Old 13-04-2008
Trader Rating: (0)
I cant find a black and white wire, there are a lot of wires all taped up inc 3 thick black ones but no black and white
Garygadge is offline
Old 15-04-2008
Multijet 130
tommy_8884's Avatar
Trader Rating: (0)
ok, if you follow the reverve light wire up from the light, it comes together with the fog light wire and numberplate wires then goes through the grommet. The colours may be different on your car. If you look closely right by where the wire connects to the lamp you should be able to see the colours your looking for. The solid black should be the earth and the other wil be positive. Note that it does not matter which earth you connect it to, so if there is more than one black wire chose any, or just connected to any un painted metal part of the car.
Old 16-04-2008
Trader Rating: (0)
Maybe it would help if the bumper was off? LOL. I didnt have to do this as I have a different kind of parking sensors, I have the wires from it inside the car in the "cubby hole" but have no idea which wires to connect it to, there must be 20 wires altogether. Ah well, another job for the weekend
Old 20-04-2008
snownrock's Avatar
Trader Rating: (0)
Greate guide tommy!
Are the sensors working well then? Im always sceptical when something is so cheap like this. Do they pick up thin bollards etc?
Current car: New Orleans Blue 06 Fiat Grande Punto Sporting, 1.9Mjet A sleeper, soon to have roof bars and a 415ltr roof box, a touring tour-de-force.
Last car: White '00 Skoda Fabia 1.4mpi Classic (Now SWMBO's) (A trooper, 44k in 18 months)
snownrock is offline
Old 29-04-2008
Multijet 130
tommy_8884's Avatar
Trader Rating: (0)
Originally Posted by snownrock View Post
Greate guide tommy!
I will have to be honest and say no! They are ok most of the time but didnt seem to warn me i was about to reverse into a car yesterday! Now i have done all the hard work i can easily replace them with better ones though!
Old 04-07-2008
Alex_gregory_uk's Avatar
Trader Rating: (0)
Great guide tommy_8884, did this today following the guide and was made really easy. Thanks again.
White GP sporting 1.9, Skydome roof, parking sensors, debadged, red calipers, lowered on Eibach sportlines, black gloss alloys, clear rear fog light, black vinyled front, merkur upper and lower grills.
Alex_gregory_uk is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Parking Sensors Ozzie1989 Leisure Lounge 18 06-05-2008 21:03
Reverse parking sensors georgios1976 Grande Punto 9 20-04-2008 22:33
Fitting parking sensors to Stilo MW nibbles Stilo 8 12-03-2007 14:03
Help fitting rear parking sensors. MrLudwig Grande Punto > Technical 9 15-08-2006 13:20
Reverse parking sensors. anthemmaster Stilo > Technical 5 21-05-2006 11:46
