The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Fitting Reverse Parking Sensors<!-- google_ad_section_end -->
4 sensor with LED display type
Published by tommy_8884
09-04-2008
Cool Fitting the sensors
Ok so the bumper should be off?!?
Its drilling time
Step 3, Drilling the holes:
If you have a workbench use it, and put the bumper on so you can see the inside(use towels again):
Once like this you should be able to see the 4 marks that fiat have kindly put there, They are cicles like the one shown here. (difficult to see sorry)
Using a small drill bit drill a pilot hole in the centre of all 4 circles. The reason for this is you should not drill the main holes from this side as the heat from drilling may warp the plastic (so vemco advises me). Once drilled, trun the bumper over and drill the main holes:
Now the holes are drilled feed the wire of your sensors through and pop the sensors themselves in and they should look nice like this:
Step 4. Wiring and finishing up.
At this point make sure you label your wires so you know which one is which when you get the bumper back on. I did mine from left to right like L1, L2, R2 R1, but do it however you want.
Next set the bumper down on the floor by the car. Now to get the 4 wires in the car. There is a rubber gromet on the back of the car and you will see the fog and revers lights going in there (photo didnt come out, sorry) Stab it with a stanley knife and feed the 4 wires in. Once in the boot, feed them under the carpet on the left into the cubby hole. This is used for the optional extras fuse box, i dont have one so its empty.
Ok next is to get the wire from the reverse lamp. I strongly advise making the connection in the car, not outside. You can do it in the cubby hole mentioned above, i did it where shown below for easy access.
Get a stanley knife and cut back the black tape surrounding the wires. You need the Thick black wire(-) and the black and white wire(+) out of the bunch. The other wires are number plate and fog lamps. Strip them back and attatch the wire from your kit to the correct wires. Solder them if you want or just wrap in electrical tape.
At this point i put the bumper back on the car without doing the screws and then pulled the rest of the exess wire into the car.
Now connect all 4 sensors, the power and your display to the controll box and stuff it all in the cubby hole.
Then decide where you want to put the display if you have one. I chose here on the boot lid by the rear wiper (cos its backwards in the mirror i inverted the order the sensors were pluggled in):
Now get in the car, turn on the ignition put in reverse (without starting engine) and test it. It worked first time. Good stuff.
Now put your car back together! (sorry im bored now but im sure you can work it out from here)
Hope it helps.
Comments welcome
(sorry for the spelling i was rushing)
Tommy
Contents
Article Tools
<<  <    (Page 2 of 2)    > >>
The following 2 users say "Thank You!" to tommy_8884 for this useful post:
Alex_gregory_uk (04-07-2008), snownrock (20-04-2008)
Old 09-04-2008   #1
Tom - 1.9 GP Sporting
venomco's Avatar
Trader Rating: (0)
venomco has donated! United Kingdom
Re: Fitting Reverse Parking Sensors
Yay you used a towel / blanket
Good guide btw
1st FRONT VINYLED GP, SIDE STRIPES, TINTED WINDOWS, ABARTH BADGES, RED INTERIOR STITCHING, ABARTH HEAD RESTS, ABARTH CARPETS, FULL VIBE SOUND SYSTEM, 12" VIBE SUB, 800w VIBE AMP, 1200w VIBE AMP, VIBE FRONT AND REAR SPEAKERS, 177BHP, LED DAY RUNNING LIGHTS, RED CALIPERS, DRIVING CAMERA, REVERSE SENSORS, BLACK ALLOYS
venomco is online now
Old 09-04-2008   #2
NFFC
tommy_8884's Avatar
Trader Rating: (0)
tommy_8884 has donated! United Kingdom
Good guide btw
Thanks. Could not have done it without yours and others advice!
The guide took longer than the job!
57 Plate GPS Multijet 130, Black
Red Painted Calipers, Footwell LEDs, Reverse Parking Sensors, Vibe Front Components, 12" Active Vibe Sub
tommy_8884 is offline
Old 13-04-2008   #3
Trader Rating: (0)
I cant find a black and white wire, there are a lot of wires all taped up inc 3 thick black ones but no black and white
Garygadge is offline
Old 15-04-2008   #4
NFFC
tommy_8884's Avatar
Trader Rating: (0)
ok, if you follow the reverve light wire up from the light, it comes together with the fog light wire and numberplate wires then goes through the grommet. The colours may be different on your car. If you look closely right by where the wire connects to the lamp you should be able to see the colours your looking for. The solid black should be the earth and the other wil be positive. Note that it does not matter which earth you connect it to, so if there is more than one black wire chose any, or just connected to any un painted metal part of the car.
Old 16-04-2008   #5
Trader Rating: (0)
Maybe it would help if the bumper was off? LOL. I didnt have to do this as I have a different kind of parking sensors, I have the wires from it inside the car in the "cubby hole" but have no idea which wires to connect it to, there must be 20 wires altogether. Ah well, another job for the weekend
Old 20-04-2008   #6
Trader Rating: (0)
Greate guide tommy!
Are the sensors working well then? Im always sceptical when something is so cheap like this. Do they pick up thin bollards etc?
snownrock is offline
Old 29-04-2008   #7
NFFC
tommy_8884's Avatar
Trader Rating: (0)
Originally Posted by snownrock View Post
Greate guide tommy!
I will have to be honest and say no! They are ok most of the time but didnt seem to warn me i was about to reverse into a car yesterday! Now i have done all the hard work i can easily replace them with better ones though!
Old 04-07-2008   #8
Alex_gregory_uk's Avatar
Trader Rating: (0)
Great guide tommy_8884, did this today following the guide and was made really easy. Thanks again.
White GP sporting 1.9, Skydome roof, parking sensors, debadged, red calipers, lowered on Eibach sportlines, black gloss alloys, clear rear fog light, LED numberplate lights, MTEC sidelight bulbs, Silvervision indicator bulbs, black vinyled front, merkur upper and lower grills.
Alex_gregory_uk is online now
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(G) Reverse parking sensors georgios1976 Grande Punto 20 1 Week Ago 19:29
Parking Sensors Ozzie1989 Leisure Lounge 18 06-05-2008 22:03
(G) Fitting parking sensors to Stilo MW nibbles Stilo 8 12-03-2007 15:03
(T) Help fitting rear parking sensors. MrLudwig Grande Punto 9 15-08-2006 14:20
(T) Reverse parking sensors. anthemmaster Stilo 5 21-05-2006 12:46
