The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Front Vinyl<!-- google_ad_section_end -->
Front Vinyl
Published by venomco
08-04-2008
Front Vinyl
This is somewhat a tw@ of a job to do, but well worth it.
What you really need is:
- A Scalpel or sharp blade
- An Old credit card
- A Tiny, and I mean TINY, pin
- Tape measure
- A hair dryer
- Patience
First off you need to measure the widest points of the grill, side to side and top to bottom. Then on the back of your vinyl (should be white) mark up these points and cut out the square these markings should create. It may be worth adding a few mm incase of any inaccuracies.
Clean the car where it's going obviously, then peel back and LIGHTLY apply, light enough that you can pull it off if it doesn't line up.
Once you're happy that it will reach the edges then slowly use your card to flatten the vinyl on one side to the other - this is so you can peel back to fix any major bubbles, don't worry about tiny bubbles at this point - they are easy to fix later.
Once fitted it's ok to use the scapel to cut off any excess vinyl, don't cut to hard though as although it wont cause rust (bumper is plastic ) you shouldn't cut into the paint. After neating up the edges you can start with the little bubbles.
This requires the hair dryer and the pin, put on a low heat and pierce the bubbles, then flatten with the card, you wont see the pin holes as long as the vinyl is heated and the needle is tiny.
I know it's not a great walk through but it may help.
Tom
Article Tools
The following 3 users say "Thank You!" to venomco for this useful post:
DTPnorfolk (08-04-2008), sp!n (26-04-2008), tomelsmore (10-05-2008)
Old 25-05-2008
jk.
jk.'s Avatar
Trader Rating: (0)
Re: Front Vinyl
sounds like a bodge job? any pics?
2008 GPS 1.9 Mjet
2004 Civic Type R 2.0
2007 Astra VXR 2.0turbo
2001 Punto HGT 1.8
jk. is offline
Old 03-06-2008
tomelsmore's Avatar
Trader Rating: (0)
Re: Front Vinyl
I would recommend applying the vinyl using a spray of soapy water as it allows you to move it around and move out the bubbles. I used a hairdrier to help dry the vinyl making it stick. Look it up on youtube for video walk-throughs.
New Orleans Blue, 1.2 Dymanic GP, Red calipers, blue LED interior neons, DIY audio jack for playing my ipod touch, vinyl grille and Philips X-treme Headlights
tomelsmore is offline
Old 03-06-2008
Tom - 1.9 GP Sporting
venomco's Avatar
Trader Rating: (0)
venomco has donated! United Kingdom
Re: Front Vinyl
jk. - All of the posts I've seen you make have been far from constructive, some down right insulting. You're relatively new to the forum yet you seem to have already got a few members backs up. It may not be your intention, however it comes across as if you are only out to offend.
If it was a bodge job, then why would atleast 10 members on here have copied the idea?
Start adding constructive comments or do one.
@ Elsmore - thats good advice actually, but becareful - some vinyl can lose its adhesive when wet.
Tom
1st FRONT VINYLED GP, SIDE STRIPES, TINTED WINDOWS, ABARTH BADGES, RED INTERIOR STITCHING, ABARTH HEAD RESTS, ABARTH CARPETS, FULL VIBE SOUND SYSTEM, 12" VIBE SUB, 800w VIBE AMP, 1200w VIBE AMP, VIBE FRONT AND REAR SPEAKERS, 177BHP, LED DAY RUNNING LIGHTS, RED CALIPERS, DRIVING CAMERA, REVERSE SENSORS, BLACK ALLOYS
venomco is offline
Old 04-06-2008
tomelsmore's Avatar
Trader Rating: (0)
Re: Front Vinyl
thats good advice actually, but becareful - some vinyl lose its adhesive when wet.
Tom
Yer as long as you squeeze the water out you should be ok. The hairdrier is a must have as it speeds up the process.
Elsmore
Old 15-06-2008
Mark Clark
Trader Rating: (0)
scorchedbee has donated! United Kingdom
Re: Front Vinyl
had a go its not great by no means, but im happy for a 1st attempt doing something like this!
can see it in these two pics
scorchedbee is offline
Old 15-06-2008
tomelsmore's Avatar
Trader Rating: (0)
Re: Front Vinyl
Originally Posted by scorchedbee View Post
had a go its not great by no means, but im happy for a 1st attempt doing something like this!=
Looks good!
Old 17-06-2008
venomco's Avatar
Trader Rating: (0)
Re: Front Vinyl
Looks good mate, but ur wheel's fallen off
venomco is offline
Old 17-06-2008
Mark Clark
Trader Rating: (0)
Re: Front Vinyl
it went for a roll down the drive
was painting my brake calipers at the time so while wheel was off gave a good clean
Old 4 Weeks Ago
haribo88's Avatar
Trader Rating: (0)
Re: Front Vinyl
im happy with this guide that much, that i now feel i have the confidence to try it on my car, thanx. but wheres the best place to get hold of the vinyl????
haribo88 is offline
Old 4 Weeks Ago
Panda Powered Squirrel
udtrev's Avatar
Trader Rating: (0)
udtrev has donated! United Kingdom
Talking Re: Front Vinyl
That's good advice, I used soapy water when sticking a rear wheel cover decal, made life far easier
Trev
Originally Posted by Most Easterly Panda's View Post
did you know that the Fiat dealership manuals recomend that the engines are dropped out the bottom of the engine
I was having a senior moment Silly me
Clarkson may have failed to kill a Toyota Hilux - I, unfortunately, succeeded :-(
udtrev is offline
Old 4 Weeks Ago
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Front Vinyl
pictures?
T14086 is offline
Old 4 Weeks Ago
udtrev's Avatar
Trader Rating: (0)
Re: Front Vinyl
Originally Posted by T14086 View Post
pictures?
Here
udtrev is offline
Old 6 Days Ago
Trader Rating: (0)
Re: Front Vinyl
any chance of puttin a clear pic of it up?
boddahchris is offline
Old 6 Days Ago
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Re: Front Vinyl
Originally Posted by udtrev View Post
Here
LOL I actually ment pictures for the guide (venomco) but errr nice hippo pic anyway
T14086 is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
GP vinyl between the grilles loudpunto Put it to the Vote... 8 13-06-2008 12:31
Vinyl! Tym Grande Punto > Styling 12 25-03-2008 18:06
vinyl? Aid1987 Punto > Styling 8 08-07-2007 20:46
Vinyl suppliers The Beast Leisure Lounge 7 30-05-2007 19:04
Vinyl Repair jasper Panda (New) 0 30-06-2005 16:53
