The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Generic MP3 input on active HU<!-- google_ad_section_end -->
Published by Andy Monty
21-12-2007
This is really easy to do and should only cost you a couple of quid!
Firstly you will need to make up a lead.
the cheapest way to do this is to use a cheap pair of 3.5mm jack plug headphones from the likes of Pound stretcher as long as they have a longish lead..
Cut the ear phones off the lead, marking the right and left earphone wire
strip the plastic off the wire (they are normally Enameled wire one gold and one red/ blue or green)
untwist and separate the 2 separate wires on each wire twist the gold wires together these are the Earth, the other 2 regardless of colour (are + left or = right Hence you labeled right and left before you cut the ear phones off)
next heat the very ends of the wire to burn the enamel off with a lighter nevt cover each bit in heat shrink leaving enough room to fold the wire over 4 times and fit a 110 red crimp onto the wire end (repeat for all three wires ((there are three wires now as you paired up the gold wires (((GND)))
next insulate the crimps (i used heat shrink)
and use some tape to hold the wires into the crimp as an added fail safe
next pop the headunit out
locate the AUX socket
your looking for A.AF-R (PLUG THE RIGHT wire in)
A.A (earth symbol)
A.AF-L (plug the left wire in)
put back together and test.. ( i just run the wire out of the corner of the HU the wire is thin enough to push back in to the void round the HU when not in use and pull out when wanted)
I will try and get some pictures up once i find my digital camera...
Article Tools
Old 21-12-2007
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
Re: Generic MP3 input on active HU
Just discovered that the car picks up the noise of the engine so by the looks of it i need better screened cable or a ferrite suppressor...
Andy Monty is online now
Old 22-12-2007
Andy Monty's Avatar
Trader Rating: (0)
Bought some screened cable today and had another go and it works perfectly total cost £5
Old 22-12-2007
Andy Monty's Avatar
Trader Rating: (0)
heres a few pics.. Cant add them above the edit option has vanished..
Wiring diagram
http://www.flickr.com/photos/16533236@N04/2129167286/
wires into HU
http://www.flickr.com/photos/16533236@N04/2129167450/
jack plug
http://www.flickr.com/photos/16533236@N04/2129167070/
Old 26-01-2008
Trader Rating: (0)
So is this any good for a Stilo head unit? Also do you have to select the input (AUX) or is it automatic?
NumanR
NumanR is offline
Old 27-01-2008
Andy Monty's Avatar
Trader Rating: (0)
dont know about the stylo...
but i manually select aux by pressing cd twice....
The following user says "Thank You!" to Andy Monty for this useful post:
richieboy (4 Weeks Ago)
Old 03-03-2008
Will31st's Avatar
Trader Rating: (0)
This works perfectly, it took me 5 minutes todo.
total cost:
Iqon headphones £6
Halfords Spade connectors £2.99
10 minutes out of my time £priceless
i do get a little interance from the engine when my ipod is paused and the volume is up full blast but when the ipod is playing u cant here a thing.
Will31st is offline
Old 10-03-2008
Trader Rating: (0)
Hi, My Stilo doesnt have an aux, is there any way I can create one?
jfella01 is offline
Old 18-03-2008
Trader Rating: (0)
Did you know that you can order a lead from halfords that connects to the back of the HU for around £3-£4 ?
Garygadge is offline
Old 23-03-2008
Trader Rating: (0)
what lead is that mate?
jfella01 is offline
Old 24-05-2008
tomelsmore's Avatar
Trader Rating: (0)
Just did mine now, bit of a squeeze but done, great sound quality, got my iPod touch connected and am surfing the wi-fi from my house. Don't get interference luckily. Thanks. Oh and I used a wire coat hanger to get the HU out.
New Orleans Blue, 1.2 Dymanic GP, Red calipers, blue LED interior neons, DIY audio jack for playing my ipod touch, vinyl grille and Philips X-treme Headlights
tomelsmore is offline
Old 25-05-2008
Unpredictable
Skitz's Avatar
Trader Rating: (0)
Skitz has donated! United Kingdom
I tried to do this today and i didnt have anyluck im confused, i got a 3.5mm Jack Lead & Some Spade Connectors... But when i pulled the HU out i had not clue where i was meant to put the wires.. =|
2008 Grande Punto 1.2 Active Crossover Black, 17" Arays AR1 Red Lip
Skitz is offline
Old 26-05-2008
tomelsmore's Avatar
Trader Rating: (0)
Hey, its weird that your HU has no labels, but having compared it to the wiring diagram I have labelled the connectors I believe are for the AUX. However I am not sure, best thing is to give it ago, the worst thing that could happen is you blow the fuse which are easy to replace i'm sure.
ID:	44198  Click image for larger version
Old 26-05-2008
Unpredictable
Skitz's Avatar
Trader Rating: (0)
Ahh Cheers mate could you maybe take a pic of your HU?
Skitz is offline
Old 26-05-2008
tomelsmore's Avatar
Trader Rating: (0)
It is the same as yours with labels, I'll take a photo in moment - do you want a pic of the label? or the connections?
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
MP3 on CD-charger input nidza Stilo > Technical 10 07-03-2008 10:48
Megasquirt construction project kritip Cinq/Sei > Technical 88 03-01-2008 19:46
Composite input problem bulldog5046 Leisure Lounge 14 02-01-2007 19:14
MP3 Player Help Steven Leisure Lounge 15 08-12-2005 19:12
UK MP3 ????? cookie Lets Talk FIAT 3 03-12-2003 18:26
