The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Interior footwell lights<!-- google_ad_section_end -->
Published by Alex_gregory_uk
12-12-2007
What will you need???
Two LED strip lights, the exact ones I bought are... Lights
Zip ties of various lengths
The smallest terminal block you can find
3 metres of 2 core cable
How long will it take???
Should take 10 to 15 minutes
Where to start???
First job is to remove the interior light, this is done by simply pulling it down from the rear, it will then pop out.
Make sure all switches are in the off position. Open the door part on the interior light from one end.
It then took me a while to establish which metal strips did what. I decided to take my feed off the passenger light bulb so connected one end of the 3 metre cable to each side of the passenger light bulb. At this stage it doesn't matter which wire is connected to which side of the bulb. So I did not have to cut any wires etc I placed the cable under the correct bit of metal wire strip. Hard to explain really!!!!
Now take the 3 metre cable and place it along the roof liner to the passenger side. It should just push up and hide in the roof liner.
You can now reattach the interior light.
Pull the door seal off from where the roof liner starts, all the way down the front of the door to the bottom. You will see there is now a gap to place the wire in (between the two red lines!!!).
Take the other end of the wire and feed it through the gap from the door seal to the back of the glove box. Rough position shown by red arrow.
Place the wire in behind the door seal and reapply the door seal.
I then connected the end of the wire into the terminal block. I tested which wire from the LED strip needed to go into which side of the terminal block (don't worry it won't damage your LED strip if it's the wrong way) one will light the strip up when you turn your interior light on. Remember this.
Now position the two LED strips where you want them. I just zip tied them both in position.
I took the wire from the drivers side behind the dashboard by removing the stereo, feeding the wire across and then out into the passenger footwell.
Now connect the two wires of the led strips together and place into the correct side of the terminal block.
Test the lights which should all be working. Zip tie any loose cables up behind the glovebox out the way.
The way mine works is if the car is unlocked the come on, if the car is locked they fade out, if the engine is started they fade out, if the engine is turned off they come on. If both interiror lights are turned on they come on, if the passenger reading light comes on so do the footwell, if the drivers reading light is turned on, the footwell lights don't come on.
Any questions you have, ask away and I'll see what I can do.
Article Tools
The following 2 users say "Thank You!" to Alex_gregory_uk for this useful post:
BlahRules (23-06-2008), Super Noob (12-12-2007)
Old 29-12-2007   #1
Smally's Avatar
Trader Rating: (0)
Smally has donated! United Kingdom
Re: Interior footwell lights
i have the other centre light so what do u do then?
Smally is offline
Old 30-12-2007   #2
Alex_gregory_uk's Avatar
Trader Rating: (0)
I'm not sure what the other interior light looks like. Any pictures and I'll try and guide you through it.
Alex
White GP sporting 1.9, Skydome roof, parking sensors, debadged, red calipers, lowered on Eibach sportlines, black gloss alloys, clear rear fog light, black vinyled front, merkur upper and lower grills.
Alex_gregory_uk is offline
Old 02-01-2008   #3
Trader Rating: (0)
Thanks bro! I ve done it today with your guide in few minutes.
I ve changed interior light to white LED too.
carlosfu2 is offline
Old 31-03-2008   #4
tomelsmore's Avatar
Trader Rating: (0)
Thanks for the guide! Did it 2day! Also added blue LEDs in the roof light. Looks really cool!
tomelsmore is offline
Old 31-03-2008   #5
Trader Rating: (0)
Good stuff, pleased to help you both.
Old 03-04-2008   #6
tomelsmore's Avatar
Trader Rating: (0)
I do recommend that you disconnect the car's battery before doing to avoid blowing the fuse. The punto does not come with any spare.
I used Blue LED light stripes from Halfords, they were powered by the cigarette socket so i just cut the plug off. I just love unlocking my car as the car starts glowing, my mates thought it was awesome. Next project to do the boot with the same idea linking off the light again.
Old 09-04-2008   #7
NFFC
tommy_8884's Avatar
Trader Rating: (0)
tommy_8884 has donated! United Kingdom
Or jsut pull the fuse out
57 Plate GPS Multijet 130, Black
Red Painted Calipers, Footwell LEDs, Reverse Parking Sensors, Vibe Front Components, 12" Active Vibe Sub
tommy_8884 is offline
Old 12-04-2008   #8
tomelsmore's Avatar
Trader Rating: (0)
Very true, I was just making sure I didn't fuse anything by mistake.
Old 12-04-2008   #9
tomelsmore's Avatar
Trader Rating: (0)
Here are photos of my blue interior lights
ID:	41646  Click image for larger version
Old 06-05-2008   #10
Lee.Johnston's Avatar
Trader Rating: (0)
WOW that does look really good. Might give this a go however I have a diffrent type of centre light will try and get pictures on here.
As I am more of a n00b than the word n00b could discribe. Would you be able to tell me where you got them parts from? As the links are not working anymore!
Thanks!
Lee.Johnston is offline
Old 10-05-2008   #11
tomelsmore's Avatar
Trader Rating: (0)
Lee,
You can get the LED lights from places like halfords, Mine were £16 each I seem to remember. I bought ones which plugged into the cigarette lighter and just cut off the adapters.
For the electrical cable any electrical DIY shop will have it. Ask for 5 metres to be safe, you can always cut excess off.
Here is the link to the halfords lighting section:
Halfords Lighting
Any problems don't hesitate to contact me,
Tom
New Orleans Blue, 1.2 Dymanic GP, Red calipers, blue LED interior neons, DIY audio jack for playing my ipod touch, vinyl grille and Philips X-treme Headlights
Old 15-05-2008   #12
Trader Rating: (0)
Hi Tom,
I am thinking about doing this some time soon and I wondered what cables you connect to each other.. as my centre consol light has three cables one yellow one red one black. Just wondering which ones you have to connect to which? Also what terminal block did you use? I have the other interior light also I will try and post pics. Hopefully! Also what size neons did you use?
Cheers In Advance
Old 10-06-2008   #13
Trader Rating: (0)
IS THERE A WAY TO DO THIS WITHOUT WIRING INTO THE CARS ELECTRICAL SYSTEM OR USING THE CIGARET LIGHTER ONES
AMAZINGLENNIE is offline
Old 18-06-2008   #14
Trader Rating: (0)
how about using the boot light... connect it to their... is that possible?
BlahRules is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Problem with lights Bionic Punto Punto > Technical 4 16-06-2006 09:12
Bravo,light prob,dash and back lights dinobaby100 Bravo/a > Technical 2 31-05-2006 18:30
stilo lights and airbag warning efrules Stilo > Technical 34 23-05-2006 09:08
Cinq Sporting Electrical Problem - Brake lights/rear lights namb Cinq/Sei > Technical 3 20-02-2005 17:00
head lights ryan_welsh Lets Talk FIAT 7 23-01-2005 22:26
