The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Changing the front speakers walkthrough (With Pics)<!-- google_ad_section_end -->
Published by captain chaos
09-08-2007
So, standard speakers not quite good enough for you?
Bit of a muppet when it comes to DIY?
Fear not, for I shall show you how easy changing the speakers can be!
Lets Begin!
Undo your plastic door trim from the door.
This is achieved by first removing the 5 screws from the bottom of the panel.
Then remove the 2 5mm hex bolts with an allen key.
Remove the blanking plastic cap behind the door release handle and remove the 5mm hex bolt with an allen key.
All the screws and bolts are now removed from the door.
Now we need to remove the panel. To do this place your hand behind the plastic panel (I found that the bottom outer corner works best).
Give a sharp pull towards you and you will see the blue plastic rivets give way, work your way around the door until all the plastic clips are free.
The door will now only be held on by the window seal. Pull the panel slightly towards you from the bottom and apply pressure upwards, this will then remove the lip from the window/door and allow the panel to be removed! Take care not to drop the panel as it is connected to the electric windows, mirror, door release and tweater!
Place a bit of carpet etc on the ground to rest your door on (dont want it scratched do you). You can choose to remove the cables attached to the plastic trim or work with them attached. I suggest working with care whilst they are still attached.
Remove the speaker cable from the existing speaker.
Using a 5mm drill bit, drill the top from each securing rivet.
Remove the speaker from the door (Laugh out how crap it is).
Using a 3mm drill bit, drill out the remains of the pop rivets.
Brush the swarf / remains of the pop rivets out of the internal door though the drain hole at the bottom.
Cut the existing speaker cables plug off.
Strip back each wire to expose the inner core.
Attach a length of speaker wire to each and wrap with electrical tape.
Crimp the appropriate spade connectors to the far end and if your feeling very fruity attach the grommets to match!
Run the wire through the internal of the door so it appears on the inside of the door, ready for your new bad lads!
Offer the new speaker up to the door and you will most likely find that the holes from the existing speakers are no where even close to fitting.
Mark out the holes around the new speaker brackets with a marker against the door.
Remove speaker.
Drill out new holes with a 3.5mm drill bit.
Remove any swarf from the drilling.
Replace with new speaker and connect to the correct wires.
Using a pop rivet gun. Rivet the new speaker into place. (You can just use bolts or screws however a rivet is less likely to shake free!)
Job Done!
Replace the door skin, first drop the widow seal back over the lip of the door and push down into place.
When the door poppers are in place, thump the door to push them back in. Taking care not to snap them!
Screw in all 5 screws and all of the hex bolts!
Replace the handle blanking cover.
Test for vibration!
DONE
Oh and throw the old speakers away!!! They offend me!
Article Tools
The following user says "Thank You!" to captain chaos for this useful post:
djdeano313 (17-10-2008)
Old 10-08-2007   #1
captain chaos's Avatar
Trader Rating: (0)
Re: Changing the front speakers walkthrough (With Pics)
Speaker Sizes / info:-
Fronts are 6 1/2 inchs or 165mm in diameter with 40w max power.
Seperate Tweeters located by the door handle offer 30w max power.
Rears are 5 inchs or 130mm in diameter with 40w max power.
captain chaos is offline
Old 28-08-2007   #2
brickdog's Avatar
Trader Rating: (0)
With the assistance of Captain Chaos I have now replaced my front speakers, including tweeters with an Infinity Kappa component set with passive crossover
The crossover fits snugly (and with no rattles) into the cavity behind the handle used to close the door
Also if you do decide to pop-rivet the speaker two or three pop-rivets will suffice and give a very solid fit - as you can see in the picture I didn't pop-rivet the top but the other three held the speaker so tightly I couldn't move the top of the speaker at all.
ID:	32091  Click image for larger version
brickdog is offline
Old 02-09-2007   #3
brickdog's Avatar
Trader Rating: (0)
For information - the Infinity tweeters I fitted had a slightly larger diameter than the factory ones so they wouldn't slot all the way in.
To get round this Captain Chaos kindly hot-glue-gunned the tweeters as far into place as possible - a simple but effective work around
brickdog is offline
Old 18-01-2008   #4
blade2108's Avatar
Trader Rating: (0)
did u just cut the wire off the tweeters and wire the crossover from the main door speakers?
blade2108 is offline
Old 28-01-2008   #5
Trader Rating: (0)
is it the same for the back speakers?
n6ata is offline
Old 04-02-2008   #6
Mo bass
dannyb-with-a-gp's Avatar
Trader Rating: (0)
dannyb-with-a-gp has donated! United Kingdom
5.25" rear speakers yes?
dannyb-with-a-gp is online now
Old 09-03-2008   #7
Trader Rating: (0)
Hi Captain, I am sorry to bother you, but do you know the maximum depth of speaker you can put in the door of a Grande Punto, Looking forward to hearing from you.
Many thanks
Sean.
seanfry is offline
Old 22-07-2008   #8
Trader Rating: (0)
Many thanks
Sean.
No idea now tbh.
I will say tho not to go too big, as you will hit the glass of the window when they are open!
Old 11-08-2008   #9
Boxer_BertDUB's Avatar
Trader Rating: (0)
Originally Posted by captain chaos View Post
No idea now tbh.
I know its a bit late but what speakers did you use ??
Did they fit alrite ??
cheerz x
1.2 8v Fiat Grande Punto DUB edition !!
Practice does Not make perfect.......Perfect practice makes perfect.
Boxer_BertDUB is offline
Old 11-08-2008   #10
fenton_jd's Avatar
Trader Rating: (0)
cheerz x
He used Fly 60watt RMS speakers (doesnt sound like much but kick out some good sounds).
I had them in my previous car, using an aftermarket headunit. They dont sound as good with the GP headunit as it cannot provide enough power.
Amped up they would sound pretty damn good, excellent bass also.
"Spirito di Punto"
fenton_jd is offline
Old 17-10-2008   #11
Trader Rating: (0)
I fitted some JBL CS2165 - fitted perfectly and sound awesome hooked up to my kenwood HU - now to attempt the back speakers.....
1.4 16v Starjet Active Sport, Chemical Grey, Kenwood KDC-BT8041 Head Unit and JBL CS2165 units in front, Philips X-Treme Bulbs, Team Dynamics RVR II 17" wrapped in Bridgestone's finest, Eibach Springs
djdeano313 is offline
Old 17-10-2008   #12
Trader Rating: (0)
one thing that could have made this perfect - colours for the speaker wires - took a bit of research
Comment
Tags
changing speakers, front speakers, speaker sizes
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
Front speakers for MK2 Punto sporting dobson2k I.C.E 11 14-03-2006 22:13
(S) Front door speakers Amir Bravo / Brava 1 04-03-2006 14:17
mk2 front speakers naz85 I.C.E 14 29-01-2006 23:12
(S) Updated price list 21/04/2004 Body Stylist Punto 30 09-04-2005 17:02
(S) Punto 75 SX P Reg Front Speakers chapmanio Punto 1 12-02-2005 17:32
