Comment
Guide Tools
Changing the front speakers walkthrough (With Pics)
captain chaos
09-08-2007
So, standard speakers not quite good enough for you? <img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> <br />
<br />
Bit of a muppet when it comes to DIY?<img src="/images/smilies/banghead.gif" border="0" alt="" title="Bangs Head" class="inlineimg" /> <br />
Old 05-05-2012   #30
Slowly getting there...
TheSilverFox's Avatar
TheSilverFox has donated!
Re: Changing the front speakers walkthrough (With Pics)
Absolutely brilliant guide cheers mate! I terminal blocked the old to new wire together for an easier swap/removal/re-installation in case of sale/upgrade!
Thanks again!
TheSilverFox is offline Reply With Quote Quote
Old 26-07-2012   #31
helped me a ton
ajtheclaret is offline Reply With Quote Quote
Old 13-08-2012   #32
Hello,
I am new here how do you replace the whole speaker unit with an original speaker can I just take the whole old speaker unit out and put in the new one or do i still need to cut wires ?
FiatPunto11 is offline Reply With Quote Quote
Old 28-12-2012   #33
can any one help me with this please people, it just about crossovers ?
http://www.fiatforum.com/grande-punt...aker-help.html
benbrook1 is offline Reply With Quote Quote
Old 13-01-2014   #34
I can't drill the rivets out! I've got the first part of them off with the 5mm drill bit but the part that requires 3mm isn't working help
KiiTz is offline Reply With Quote Quote
Old 25-04-2014   #35
Back in a 500!
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
Quote Originally Posted by KiiTz View Post
I also found the rivets hellishly difficult today - having drilled off the head, I had to bash around with a pin punch to eventually get the centre bit out of the door metalwork.
I notice the doors have large openings in the metalwork, so mounting the speaker onto the door (not sealed against the door trim) won't sound very good. It will probably need to have all the holes sealed with bitumen sheet as shown in post #27 by Konrad.
-Alex
'15 Giulietta 1.4MA, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 02-02-2015   #36
DazEvo has donated!
is this similar for an evo?
Owner of a 2010 Punto Evo Dynamic - 1.4 8v // Modifications: Tinted windows, 17inch Alloy Wheels, Sprayed breaks, Lights converted to LED etc.
DazEvo is offline Reply With Quote Quote
Old 20-01-2016   #37
SeanSathe6035 has donated!
Hi guys,
New to this only had my 56 Grande Punto a few months and the speakers have to go. I have ordered a set of Co-axial speakers to go with my SONY Bluetooth DSX-A60BT head unit but I am looking at the section where you wire new speaker wire into the existing cable on the car. But because my new speakers are co-axials I have been told I can use the existing wire already in the car? Is this true. I have speaker cable from my dads amps and home cinema system so I can put it in but just wondering if I really need to, thanks.
SeanSathe6035 is offline Reply With Quote Quote
Old 18-06-2016   #38
I used the standard wire, you can remove the spade connectors from the standard speaker plug if you're careful using a tiny screw driver. I simply plugged those onto my new speakers and it works great.
Morron is offline Reply With Quote Quote
Comment
Guide Tools
Front speakers for MK2 Punto sporting dobson2k I.C.E 11 14-03-2006 22:13
(S) Front door speakers Amir Bravo / Brava 1 04-03-2006 14:17
mk2 front speakers naz85 I.C.E 14 29-01-2006 23:12
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 17:02
(S) Punto 75 SX P Reg Front Speakers chapmanio Punto (Mk1) 1 12-02-2005 17:32
