The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Installing a 12v boot socket<!-- google_ad_section_end -->
Published by phostead
15-07-2007
Post Installing a 12v boot socket
I have just installed a boot socket into my GP sporting. Was pretty straight forward. The socket is approx £8 inc vat from a Fiat Dealer. Not sure if all GP's have the wiring in the boot already. Easiest way to find out is to have a look in the left hand side of the boot trim (As you look into the boot). Mine had the hole pre cut, and you could see the cable, complete with prefitted multi plug, through it.
!! Caution, though this is a simple procedure, you are connecting an electrical socket in your car. I take no responsibility for you torching your car or knackering your electrics !!
Step 1:
The socket comes in 3 parts, a plastic housing, a bung for when not in use and the actual socket.
Do not be tempted (as I was) to just fit all the bits together. They must be fitted in order, otherwise they won't fit.
Step 1:
The pre cut hole in the boot trim has one part that is cut out. On the plastic housing there is a "nob" that protrudes from the rest of the housing.
Take the bung, which is attatched to a plastic "O" ring, and slide the this over the plastic housing.
Step 2:
Insert the plastic housing into the pre cut hole in the boot so that the "nob" is aligned with the cut out. Push the plastic housing through the hole, i had to do it at a bit of an angle, and it required quite a bit of persuasion.
Step 3:
Once the plastic housing has seated against the trim, twist it so that the "nob" is not behind the trim. This will secure it in the car.
Step 4:
Align the metal socket with the plastic housing. It will only go in one way, and slipped in quite easily with a little bit of a push needed at the end. Don't force the socket. I would recommend that you don't push the socket all the way in yet.
Step 5:
By now the socket should be installed in the boot, but not fully clicked in so that it is fixed. The last stage is to connect it up.
As I said, my GP Sporting has the wiring in the boot for the socket. Pull down the carpet that meets the trim, and fish around for the wire.
I pushed the connector through the housing, and then attatched it to the pins on the socket. The, GENTLY, feed the cable and the socket into the housing (remember it only goes in one way) and push it all into place.
It does not require a lot of force just a little bit of gentle persuasion, followed by a click.
That should be it. I tested mine with my phone and car charger and it worked first time (phew! )
Hope this helps. I have used it a few times and come in handy for the compressor and electric cool box.
Paul
Article Tools
Old 22-07-2007
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
Re: Installing a 12v boot socket
The active (mines a 3 door) Doesn't have the multi plug in the boot as it doesn't have the rear fuse box
However its not hard to wire it in i took a live feed direct from the battery through the bulkhead (fused with an inline blade fuse/holder 20amp at the battery) run through the grommet as per the foglamp wiring guide under the passenger side door trim (three screws) i then poped off the rear plastic panal about 1" and used a thin bamboo cane and pushed it between the rear card and the body work once at the boot with the carpeted side removed i felt for the cane and pulled the wire in by taping it to the cane whilst a mate fed the wire in as i pulled..
once at the boot hold on to it or it might spring back into the body and require re-drawing through cable tie it to stop it dropping back...
for the earth remove the 2 screws from the back panal and the large Torx bolt and carefully fold the boot seal away (the seal is double lipped one around the metal and one around the boot liner) and it comes out revealing a nice big earth post on the left of the boot..
as you dont have the multi plug i used 2 insualted female blue spade connectors. 2 blue ring terminals (one for the battery connection and one for the earth post (and 2 additional blue female blade connectors for the fuse holder).
Hope this helps in addition to phostead's guide
Andy Monty is online now
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
boot socket ! belfast_lad Stilo 6 14-03-2007 01:35
Placement of 12v (lighter) socket Soepy Panda (New) 18 13-04-2006 23:00
power socket in boot ProtoFJ Stilo > Technical 3 11-08-2005 08:58
Using the boot power socket for an amp?? Stemondo Stilo > Technical 0 06-04-2005 12:59
12v Socket in boot boywonder Stilo > Technical 30 06-11-2003 19:09
