The FIAT Forum
Go Back   The FIAT Forum > Guides > Grande Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Wiring a Towbar 12 N socket with 7 way Bypass Relay<!-- google_ad_section_end -->
Published by Andy Monty
30-06-2007
How to....
This job requires work on the vehicles electrics and might void your warranty And if done incorrectly could start a Fire
thats the disclamer out of the way
Gone are the Days when you'd just scotch hook the trailing end of the 7 way cable to the loom with the bulb failure system and Fiats notoriously small cables it cant be done for fear of melting the loom and having the check Bulb light come on every time you use the socket....
you dont need a towbar to always need road lights if you use a strap on cycle rack for example that blocks vision of your road lights you will need a light board for example..
I have left out the towbar bracket fitting instructions as these are specific to the brand of towbar you have bought
The stuff you will need are
12N socket and mounting hardware
2 mtrs of 7 core wire
1.5 to 2 mtrs of 2 core twin 1.5mm is fine
a Reel of Single core 20Amp rated cable
7 scotch hooks
7 Way Bypass relay
a blue eyelet crimp
Fuse holder and associated spade crimps
Soldering iron,
Screwdriver,
wire cutters,
stanly knife
wire strippers
insulating tape
Cable ties..
A working lighting board is handy to test
I think thats it......
Contents
Article Tools
<< <    Next Page (Page 1 of 2)    >  >>
Old 05-07-2008   #1
Fiats since 1973
johnson550's Avatar
Trader Rating: (0)
johnson550 has donated! United Kingdom
Re: Wiring a Towbar 12 N socket with 7 way Bypass Relay
if I am reading this correctly you have a 20amp fuse inline with 20amp wire in the event of a short will the wire not melt at the same time as the fuse
2007 Stilo Sporting M/Jet 150bhp
2001 Marea Weekend JTD 110bhp now 171bhp
He who works and does his best gets his cards just like the rest
johnson550 is offline
Old 19-08-2008   #2
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
bad wording on my part should read something like a cable able to take in excess of 20A
happy now
Originally Posted by Most Easterly Pandas View Post
Massive gash
Andy Monty is offline
Old 21-08-2008   #3
Trader Rating: (0)
Question Re: Wiring a Towbar 12 N socket with 7 way Bypass Relay
I have never wired a towbar on a Fiat but have done several Citroen Xantias.
If you are towing a caravan with loads of electrical loads etc, I can understand the need for a 20+ Amp wire. And even that seems huge.
I however will be using my old Multipla for a bike rack and small trailer for taking rubbish to the dump...
I cant believe that an extra bulb on each circuit in the loom from the light board is going to melt it ! The load is tiny...even on a cheapo loom...
I don't recall there being a blown bulb function on the 2002 Multipla either but I could put up with that if it came on. It would go nicely with the airbag light, I can't get that blighter to go out either.
Feel free to enlighten us further as I feel that you have done a top notch, belt and braces job that can handle everything. I am holding back now as I am more of a grease monkey than an electrician and you have got me worried.
Jimbo34 is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
Doblo Towbar Wiring Again Ozzie1989 Doblo 0 09-06-2007 23:28
(G) bloody bravo! sp33d12 Bravo / Brava 27 16-03-2007 15:39
Towbar addition Wiring colours? windy Multipla 4 27-07-2006 10:28
wiring a towbar socket simon peters Lets Talk FIAT 2 20-05-2006 20:08
(T) Towbar wiring diagram for stilo needed bofruehw Stilo 0 10-07-2003 20:58
