Cinquecento remember my nice shiny clean cinq?
450miles of motorway driving has taken the shine off it! :(
pictures taken jsut before washing it again - will be waxed later if it stays dry (y)
Latest updates
Engine
1368cc 16v Stilo engine
Lightened flywheel
Mk1 Punto Sporting inlet manifold
Bravo 1.6 16v throttle body
Brava 1.2 16v fuel rail
Stilo 1.4 16v injectors
Punto 85 Fuel pump.
Adjustable fuel pressure regulator
Megasquirt engine managment system with LC1 wideband lambda controller
SFS Hosing with BMC Carbon Dynamic Airbox
Ceramic coated Supersprint 4>2>1 manifold, decat, stainless centre section and Supersprint backbox
PuntoGT fan switch
Alloy rad.
Battery relocated to boot and massively uprated.
Brakes
257mm Vented, Red Dot 6 groove discs fast road pads.
Rear disc conversion with 240mm solid, red dot 6 groove discs with standard pads.
Suspension
Spax PSX kit with shortened adjustable dampers
60mm drop at the front and 40mm at the rear
Powder coated arms at the back with powerflex bushes.
Exterior
Abarth rear apron
Abarth rear spoiler with LED brake lights
Abarth speedline wheels
Front bumper cut out.
LED brake, and sidelights.
Interior
LED dash lights.
ECU mounted under dash.
LC1 calibration button and LEDs under dash
Ashtray removed and replaced with graphic EQ
Vacuum and AFR gauges mounted in custom A-Pillar gauge
Oil Pressure, Temperature, and Exhaust Gas Temperatre gauge mounted in centre vents.
I think that's it, spec wise.
and some pictures.
Developement thread; https://www.fiatforum.com/cinquecento-seicento/176286-my-1-4-16v-cinquecento-development-thread.html
  • Like
Reactions: SimonCento
Well thought i'd post up some recent pictures, and specs of my car.
Engine
1242 8v MPI, Punto75 Engine.
Ported, skimmed and flowed head with valve guides cut back.
Port matched inlet manifold.
Lightened flywheel
Punto 85 Fuel pump.
GSR Induction kit with BMC Carbon Dynamic Airbox
Low temp thermostat
PuntoGT fan switch
Alloy rad.
Brakes
Suspension
Shiny new wishbones and bushes at the front.
Shiny new arms at the back with powerflex bushes.
OMP Front Upper Strut Brace
Exterior
Abarth rear apron
Interior
LED dash lights.
and some pictures.
ok, so she's not running quite yet.. but everyone is happily cleaning their cars for Stanny - I can't make it, as i'll be working on Chii, but i wanted to put some pics up. Not been cleaned since last November :eek:
Isn't she pretty. :)
(nearly starts, favourite trick at the moment is blowing blue/purple flames out the throttle body :slayer: )
Vehicle information
FIAT Cars
arc
Views
1,099
Updates
4
Last update
More in FIAT Cars
More from arc
  • my Xsara VTS
    So since moving into the centre of Sheffield - I've had no garage / time / money to do much with...
  • Punto (Mk1) punto power!
    Thought it's a bit about time i posted some pictures up of my little punto. I rescued her, gave...
