Hi Doblovert, these photos show the bits you need and where they fit. Fitting the winder is as you say and Nyloc nuts/washers will be fine. See my previous post for part numbers. I agree, heaven knows why the LPG fitter couldn't have put all the bits in a bag and sent them with the carrier
You can see the location of the winch mechanism with the two front and 1 rear rubber-faced brackets which locate inside the wheel to hold it in place when it's raised. For some reason, the front brackets have 2 studs each but the rear bracket has one stud at the front with a bolt and captivated nut at the back - hence the 5 studs!
This is the spring loaded threaded T which fixes to the wheel with the 2 plastic turnscrews.
The large nipple on the end of the cable locates in the top of the T and is secured by the white nylon mushroom.
As you turn the winding mechanism, the wheel will be dragged along under the winch. The cable then lifts the wheel until the thread on the T engages with the winch. Continue to wind until you feel the clutch slip.
Hi Sue,
Yes my spare is steel.
I don't know if there are different turnscrews for the alloy wheel, I can't remember seeing any in the parts list. Anyway they don't affect the security of the wheel once it's wound up into position, so no problem there.
They just make it easier to attach the winch wire to the 'T' as they hold it in the correct position on the wheel, prior to sliding it under the car.
To fit them you need to lower the spare and pull it out. This will loosen the 'T' and allow you to turn it so the two screw holes in the 'T' line up with two of the wheel stud holes (see my third picture). You should then be able to push the turnscrews through the back of the wheel through the stud holes and screw them into the 'T' below. So the turnscrews are inside the wheel when it's raised i.e. you can't see them.
Hope this helps
