It's a tuscany green one!
A real pick for you all
Are you missing the space inside or is it more like a Tardis? I did wonder about a Panda at one time but the boot lip put me off knowing what I have to get in it.
Whilst browsing a rolled/dented Qubo on eBay for bits, the scrap yard had a (newish) Panda 4x4 for breaking and I was tempted to do some measuring as I'd fancy making a Qubo into a 4x4. I think it had a 6-speed box but its the g/box and rear end that would need transplanting. Is it the same 1.3 MJ engine as we have? Wonder about the viability. Need lots of time and I couldn't use my Dualogic box
R-V-M
The new 500X is available with 4x4 now. Can't see why Fiat didn't call the 500L the 600 as it looks nothing like a 500 (quite ugly really but not in a Multipla way )
R-V-M[/QOUTE]
I thought about 4x4-ing a qubo. I recon a 1.3 4x4 gearbox and transfer would just bolt on. Rear axle could be from a Sedici? But with Panda rear diff for ratio sake, plus rear drive shafts might need sedici for length but panda for flange....
Then there's the 1.2 Panda viscous coupling to fit, prop shaft supports and exhaust re-route, not to mention a new fuel Tank?
Sounds straight forward initially, and then..............
