Electric drivers side window
G
gemmjohn
Guest
My front drivers window seems to have stopped working, i have checked the switch and that is connected there seems to be a clicking coming from the motor in the door, Any suggestions? do you think this is a motor problem?
i get this with my passenger side window,it dont work.The switch is fine as you can hear it click from under the glovebox.So im presuming the motor has had it.
A Fiat Marea in a Bravo Shell..its good to be different ;)
think ill check it then at weekend
H/B cables soon to be fitted,next on list..tensioner..
Mike make sure the connection at the door is tight as mentioned above. Remember mine was loose and I had the same problem after the swap? If not then you can have the motor out of my other door that I still have.
Similar threads
C
Replies
2
Views
536
K
L
Replies
1
Views
548
Tommy K
T
M
Replies
1
Views
326
Dark Lurker
D
M
Replies
Views
6K
mick gibbons
M
